cammed and missfiring
  • e30power7931
    • Jan 2009
    • 20
    Hi everyone im new to the forum but a few weeks ago myself and a master tech rebuilt a head and put a 272 cam in. The car is missfiring in the lower rpms and really not making the same power it was stock....last sat we installed and adjustable cam gear and advanced the timing 3 teeth...and its still missfiring and not makin power....it has a vacuum leak in the brake booster where the master cylinder meets the booster and we are fixing that tomorrow and even my master tech is stumped at whats going on.....any ideas whould be greatly appreciated :stupid: THANKS!!!
  • VacMan
    • Apr 2007
    • 2405
    Sounds like you already found the problem. Vacuum leaks = bad.
    • itsbrokeagain
      • Jul 2008
      • 199
      big cam = low vacuum at idle = injector on-time goes up. Might need a chip too?
      • e30power7931
        • Jan 2009
        • 20
        thanks guys. yeah i got a chip just put it in a few hours ago....but the booster has always been like that and have had a rough idle lol. for example i have never been able to beat my friends e30 while we both had drop in filter and exhaust and it was from a 50 roll...but thats the only spot we can think of for a vacuum leak......we have checked all the others and have found nothing.....im prayin..lol keep our fingers crossed
        • winfred
          • Apr 2008
          • 72
          depending on the cam it'll can get pretty lumpy at idle and i have herd not much good about regrind cams if that is what you have, lotsa stories about them being ground wrong and never running correct
          here is what my 2.8 stroker sounds like with a BAS 280* 110 degree separation and 10.6/10.6mm lift
          cold start
          and hot
          • e30power7931
            • Jan 2009
            • 20
            yeah its a reground....fixed the break booster/master cylinder vacuum leak....runnin a ittle better... i dont know if im just being ignorant and expect a 272 to make a good difference or what....but my master tech says its acting like it has a HUGE vacuum leak.....for example...when you pull the line out of the brake booster that runs to the throttle body the car "should shut off almost immediatly"but nothing is happenin lol. we have checked all the vacuum lines such as the breather hose from he valve cover and the ones on the throttle body....were pretty stumped....
            • dashboardmonkey
              FUCK YOUR WAFFLES
              • Jun 2008
              • 6158
              Use a propane torch to check for vacuum leaks. Propane ONLY!!
              Open the valve on the torch, do NOT light torch.
              Start engine.
              Probe around vacuum hoses, gaskets and anywhere else it can leak and if your idle rises you have found a leak.
              Hope this helps you find any leaks, if in fact it is a vacuum leak.
              Andy
              -Andy
              • e30power7931
                • Jan 2009
                • 20
                thanks! ill give it a try as soon as i can
                • SpecM
                  • Oct 2005
                  • 4531
                  you prob wouln't get that much more power only that cam
                  GL with the vac leak, remember to check the EVAP vac line under the TB
                  1989 cirrisblau-metallic 325i
                  • Dyno4mance
                    • 345
                    I would question the cam timing....Why did you/or your mechanic advance the cam timing by 3 teeth? what was the logic behind that move?
                    I would also question the head rebuild
                    Are the valves seating?
                    Are they bent now?
                    Is the head gasket leaking coolant into the cylinder?
                    Has the timing belt jumped teeth?
                    Has the lash on the followers been set correctly?....Is there any clearance at all?
                    have the injector seals and isolators been checked for correct sealing?
                    It always concerns me when people use the term MASTER before technician
                    My 2c
                    2.7L M20 11:1 COMP 195 whp Dyno Dynamics 2380lbs
                    • SpecM
                      • Oct 2005
                      • 4531
                      really
                      • napabavarian
                        • Jun 2008
                        • 834
                        Where did you get the regrind?
                        This place is like catholic school, 2/3 of the students smoke weed on a daily basis, but the faculty seems to convince the outside world that drugs are just in the other schools, the resident pot dealer thinks he's cool because he has the originality to call anyone he doesn't like a homosexual, and most of the little children follow him like sheep, then there's the few with brains, you hardly ever hear from them, perhaps don't even know they exist, but they get all the sh!t done.
                        • digger
                          • Nov 2005
                          • 6216
                          advancing timing 3 teeth is a massive change i would put it back before troubleshooting any further
                          • e30power7931
                            • Jan 2009
                            • 20
                            i got an ireland engineering 272. we had it runnin for 2 weeks without the adjustable cam gear. after installing that it made the car run much better. And yes dyno4mance all of those have been checked.....and my master tech is a good friend of mine and has been a master for over 20 years. he started on e21s and has had every training course you could get.
                            • e30power7931
                              • Jan 2009
                              • 20
                              and i dunno if it was teeth per say but it was three little notches on the cam gear....it has little things that look like this.............................................. ...............................................
                              ...R | A
                              |||||||||| but kinda circular lol
