E pistons on I rods?
  • itsbrokeagain
    • Jul 2008
    • 199
    So after rummaging through some old threads, I had found the one containing the specs for all the compression ratios. I found the part number for the M20B27 (83-85 model) which is listed in the program as high compression.
    Since they come out of an E engine, is there a difference in the rods between the E and I M20s? I can get my hands on the pistons quite easily and cheap, but I would like to know before I place such an order.
  • Aptyp
    • 6584
    b27 rods are 130mm long
    b25 rods are 135mm long
    Deck Height is the same at 206mm. Now calculate your pin height and see if they'll fit.
    • whodwho
      • Jun 2008
      • 1547
      Originally posted by Aptyp
      b27 rods are 140mm long
      b27 is 130
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • Aptyp
        • 6584
        Oops, that was a typo, lol E rods are 130mm
        Pin height on E is 35mm and I it's 33. E Piston are taller.
        • whodwho
          • Jun 2008
          • 1547
          Not to get all technical on ya...;)
          E is 35.7 and I is 34.2
          Here is a good source of dimensions for m20 pistons:
          • itsbrokeagain
            • Jul 2008
            • 199
            Hrm that's a real tight setup.
            If the cranks are exactly the same, then its no go. I rods would push it up 5mm more, but the wristpin height would bring it back down less that 1mm. That's valve territory lol. Now if I swung e rods as well...
            Hrm I got some math to do...
            • Brian D
              • Mar 2006
              • 832
              I stroke is 75mm. e stroke is 81mm. You sure the early e pistons are high compression? Every one I've seen has been a flat top.
              1973 Bavaria
              • itsbrokeagain
                • Jul 2008
                • 199
                apparently it says that the 83-85 euro E engines had 11:1 compression.
                I consulted my friend at hte dealership and we poured through the part numbers and he has a listing for them..
                  • 34844
                  they are 11:1 CR in the 200/731 heads, but if you use an 885 head it will be lower. it's also the wrong shape for a good quench area on the 885 head..
