Headwork
  • Jand3rson
    • 37587
    Headwork
    I'm swapping a 325i intake manifold and throttle body onto my eta motor, so I figured it would be a good idea to enlarge the intake ports on the head to match the i intake runners. Andy did the port work, and did a really good job, here's a few pics of the head.
  • xLibelle
    • Aug 2004
    • 2673
    wow, you wasted time with an eta? Drop that shit and find an i head!
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      It's gonna go to the machine shop, right?
      • xLibelle
        • Aug 2004
        • 2673
        you know, nevermind my first comment. put it on the dyno. let us know what you put down.
        Farbin, do you sleep?
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          Sleep?
          • Jand3rson
            • 37587
            How about you buy me one instead of talking shit? I'm working with what I have.
            • dashboardmonkey
              FUCK YOUR WAFFLES
              • Jun 2008
              • 6158
              Sig worthy.
              I am curious how this works, I may take my head back off and do this.
              -Andy
              • Jand3rson
                • 37587
                I did the i manifold/TB swap before on my old eta without doing the port matching, and still saw a decent increase in throttle response, and a little bit more power up top. That was also on a non-chipped car. Should be interesting to see what it nets.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Why?
                  • StereoInstaller1
                    GAS
                    • 22679
                    Josh, did Andrew unshroud the valves a bit too? Can we get a shot inside the intake ports? Gonna touch up the exhaust side too?
                    You fucking fuck! We had a shop with a fuck ton of air, a complete head porting kit and your motor off the fucking car...and NOW you are talking about doing some porting?
                    Closing SOON!
                    Thanks for 10 years of fun!
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      Originally posted by NitroRustlerDriver
                      Why?
                      Because I like to hot tank parts that could hold small particulate matter that could gall the bore surfaces of the cylinder wall, etc. Sure would suck to put it all together, then chew up a piston ring.
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        Luke, I only port matched the intakes, nothing more.
                        And as far as particles, we stuffed bits of rags into the ports to keep out chips and then taped a plastic bag over the rest of the head. Nothing got anywhere it shouldn't have been. Not to mention we vacuumed up any shavings as we went along.
                        • 5KWattson
                          • Apr 2009
                          • 809
                          im currently porting out my I head both intake and exhaust along with the exhaust manifolds and intake manifold...mine is chipped and stroked so if i get to run mine on the dyno ill post up results
                          "God created turbo lag to give V8's a chance" Taylor D.
                          • TrentW
                            • 2815
                            Anxiously awaiting these specs if/when you get it done.
                            • Jand3rson
                              • 37587
                              You know eta and i exhaust manifolds are the same, right?
