sounds like mine when i had 2 bad rod bearings take a stethoscope and go make sure the noise isnt down at the oil pan (couldnt hurt to try)
Engine Ticking help?
I dont quite understand.. good news for me? Sorry about that.. didnt mean to be a thread stealer, but this issue has plagued me for some time, causing me to turn down quite a few nights at the track.. any help guys?sigpic"Its ugly.."
"Thanks!"Comment
I think I meant that was good news for me about what you said.
ANy luck with yours?Comment
Valve Tick
I had a valve tick. Valve adjustment was fine. Compression was good on all cylinders. People listening said run it. Second shift at 6,000 resulted in what you can see at the following:
http://flickr.com/photos/9656990@N08/3302897758/
If your tick does not go away with a valve adjustment pull the head.
It was an expensive racing lesson.
David BeagleEx Pro 3 and Chump Driver/Car Builder/Owner
1991 318is Track Car
ND Maita - Daily DriverComment
