budget stroker wiring changes? (stock I harness)
  • JAM
    • Feb 2007
    • 524
    what changes need to be made (if any) for a budget stroker (88 s-eta bottom end, 90 I head) to run on the stock 90 325is engine harness? thanks.
    Originally posted by Mr Watsonsilver
    driving boards?
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    This has been covered so many times.
    -Andy
      • 34844
      if you have the 88 seta harness you can keep the harness, but you need the B25 AFM , injectors and ECU.
      • JAM
        • Feb 2007
        • 524
        not good. ok here is the story
        a few years ago i bought a 90 325is with the budget stroker. the wiring was a sketch job but it ran great. this past summer it just started cutting out on me while driving, and then one day wouldnt start at all. i brought it to my mechanic (who mainly works on hondas and dsm's) and bought a complete 89 325i harness
        only after he had ripped the old harness out did i realize the prob was most likely caused by the power wire to the inj harness. not a big deal i figured, and helped him install the new complete harness in the car
        now where im at- harness is fully installed, the car does not crank, pump does not prime when switched on.
        so- what changes are needed to be made to make this harness work? plz help! thanks
        driving boards?
        • thereisnoyun
          • Feb 2007
          • 2301
          if you know your fuel pump doesnt kick on test it first via bentley spec. If its dead replace that. Make sure you replace the filter too if you havent. Then try it again.
          Check for spark and make sure your coilpack is to spec.
          You also want to check your CPS Its by the ac compressor, but hte connector is under the pin plug in next to the manifold. Test it to see if its via bentley spec.
          • JAM
            • Feb 2007
            • 524
            then link me please, i did a search and didnt find much
            driving boards?
            • JAM
              • Feb 2007
              • 524
              Help please!!!
              driving boards?
              • FredK
                • 14763
                The car doesn't crank, meaning turning the key does squat? Are the relays installed in the right sockets? Maybe you switched the fuel pump relay and the main relay?
                • s52e30m3
                  • 225
                  Check pins in both car and motor side of the C101. They may be different!
