cam sprocket removal
  • muppet
    • Mar 2004
    • 39
    does anyone have a way to remove the cam sprocket with the t-belt already off? I am mid-replacing my timing belt and need to replace the cam seal and o-ring, but the cam wont stay still for me to remove it. And ideas?
  • Liam
    • 753
    Deep 10mm socket through the cam cog (sprocket) on a breaker bar or ratchet on the retainer bolt to lock the cog.
    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
    • SpecM
      • Oct 2005
      • 4531
      An air ratchet works great if you have access
      1989 cirrisblau-metallic 325i
      • dashboardmonkey
        FUCK YOUR WAFFLES
        • Jun 2008
        • 6158
        You mean impact gun
        -Andy
        • Hallen
          • 1008
          Put the old T-Belt back on, tighten the tensioner and have at it. It doesn't take long to put the belt back on.
          1987 E30 325is
          1999 E46 323i
          RIP 1994 E32 740iL
          oo=[][]=oo
          • SpecM
            • Oct 2005
            • 4531
            Originally posted by dashboardmonkey
            You mean impact gun
            yea, I guess
            • Liam
              • 753
              What ever you do end up doing don't spin the camshaft.
              • E30stan
                • 658
                I used a flathead screwdriver to wedge between the cam gear and head, thats what 101 performance book for 3-series had written
                • E30SPDFRK
                  • 5703
                  You mean impact gun
                  That's a bit overkill. An air ratchet would work if the head is off, but I wouldn't risk using it if the head is still bolted down as it may spin the cam.
                  Or just place it between 2 of the bolts and hold it there. Just crack all the bolts free first before removing them all the way so you always have 2 to use.
                  Byron
                  Leichtbau
