I picked up a complete motor/tranny from a 91 325i to put in my 87 325is for $150 (Friend hooked me up big time. Mine had 260k miles, this setup has 140k).
I'm wondering what would be best/possible... swapping the 87 harness onto the 91 engine, or using the 91 engine with the 91 harness that's on it and modifying it to work with the car.
I'm guessing if I use the 91 harness, I'd need to splice a few wires from it to go to the c104 in the car. I'd also need the later O2 sensor with the big connector.
With the 87 harness, I wouldn't need to do anything, right? It will just go right onto the 91 engine with no issues?
Some things effecting my decision:
-the 87 harness lit on fire at one point and is slightly burned... it runs and drives fine, but the coolant sensor wires are a tad bit crispy
-the 91 harness has the inductive pickup on the plug wire. Those plug wires are trashed, so I'd need to buy new ones ($$$).
-the 91 is missing the CPS. Would the 87 CPS even work with the 91 harness?
-Anything else???
-Anything else???
