reseting check engine light???
  • ///Bimmerfan
    • Dec 2008
    • 730
    How do you reset the engine check light and the inspection light???
    please help me
    Thanks
    Bimmerman16
  • ///Bimmerfan
    • Dec 2008
    • 730
    bump
      The Service Indicator reset can be done by what is presented on http://www.unofficialbmw.com/repair_faqs/sil.html
      "Resetting the Check Engine light" is accomplished by determining what fault codes are present and repairs as indicated.
      • Liam
        • 753
        The MIL (Malfunction Indicator Light AKA Check Engine) will go out on DME 1.3 ~ 1.7 (all e30 systems with an MIL) on its own when the problem is solved.
        Codes are not stored like in later generations.
        I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
