Best way to get intake on and fit the oil return pipe
  • Chells_88ix
    • 61
    Been trying to get the intake manifold back on the engine after putting a replacement head on and cannot get the manifold to go if the oil return is in place. I know someone out there has done it, what is the best way?? Help! thxs, chell
  • Liam
    • 753
    Use a zip tie on the spring install the manifold and then cut the zip tie and pull it out.
    Important: don't use any sealer on the "O" rings and use a lubricant like assembly grease on the lower one (it needs to move when the engine expands and contracts with temp changes).
    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
    • Chells_88ix
      • 61
      So if you compress the spring fully the pipe should then fit? Our problem is getting it to fit once you have the manifold centered on the longer center stud, seems if it goes on the stud there isn't enough play to get the pipe to fit under the manifold and in the block hole. It almost seems like the pipe is too long but since it is the one that came off it can't be. We have cleaned up both ends to allow it plenty of clear, clean space.
      • E30Idea
        • Mar 2007
        • 2196
        Be sure the o-rings are fitted completely flat in the intake and block. this could cause a fitment issue otherwise.
        ** Lot's of M20 turbo parts for sale.**
        Turn key track car.
        http://www.r3vlimited.com/board/showthread.php?t=222066
        • Chells_88ix
          • 61
          Oh, almost forgot, the lower side only had the thin metal washer, no o-ring at all. Will normal o-rings work in place of the originals, or do I need the squared type of seals? (The top one looks like a squared 0-ring)
          • Hallen
            • 1008
            "normal" is what I got when I ordered the O rings for the pipe. Thanks for confirming the washers. Mine didn't have any on when I uninstalled it. I have some on order though. Where do the washers go with relation to the O ring?
            Anyway, on my car, all I did was put a little assembly lube on the tube and then compressed it down into the block until the spring was fully compressed. Then there is plenty of room for the intake manifold to clear the tube.
            Unfortunately, my intake manifold cracked when I was torquing it down.
            1987 E30 325is
            1999 E46 323i
            RIP 1994 E32 740iL
            oo=[][]=oo
            • Liam
              • 753
              Bottom of the return pipe gets a spring then a washer then the O ring (look in the block for the old one, sits in a grove) top gets an O ring.
              These O rings are a weird size, get them from BMW.
              It must be placed in the block 1st before the head or manifold goes on. (Don't Use Sealer)
              Manifold gets wave washers and a flat washer under 8mm X 125 nuts w/ a 12mm span.
              Torque evenly and Not so tight next time.
              • guibo09
                • Dec 2008
                • 834
                where the hell did you come from liam? 45 posts and you're already one of the most helpful guys here
                90 E30 325i
                • Liam
                  • 753
                  I'm a BMW Tech / Tuner, came out of the blue to rescue ya'll from the high post count, shade tree greasemonkey, keyboard, PS2, Nintendo, race car engineers. ;)
                  • Hallen
                    • 1008
                    It is interesting that realoem shows the nut and the washer, but no part number. Same for the ETK if I put my VIN in. But it will show them when you just select a model without the VIN. Anyway, I didn't have the washers. The PO must have lost them. I'll get some ordered. I don't see a flat washer shown in the parts manual though, just the wave washer. It is an M8 nut, so if the torque is different then standard, they really should publish it. Anyways, it was my bad. Thanks for all the tips and sorry for hijacking a thread. I have a post over in the projects forum on this too.
                    1987 E30 325is
                    1999 E46 323i
                    RIP 1994 E32 740iL
                    oo=[][]=oo
                    • Liam
                      • 753
                      The flat washer is an add-on by us old guys in the field.
                      A lot of PNs have been missing from ETK/EPC for a long time now (I think since the begining of ETK v1. I don't know why that is)
                      • Hallen
                        • 1008
                        OK, cool. I'll get a few aluminum flat washers too. There is plenty of thread space on the studs. What torque would you use? Snug? I used 15ftlbs (~22nm). I think not having the washers was part of the problem.
                        And thanks for the help.
                        1987 E30 325is
                        1999 E46 323i
                        RIP 1994 E32 740iL
                        oo=[][]=oo
                        • Jordan325iC
                          • Aug 2005
                          • 1697
                          Also, let me point out the proper way to install the bitch tube.
                          From top to bottom:
                          1 o ring on top
                          Vent tube
                          Spring
                          1 washer
                          1 o ring on bottom
                          Use two tiny zip ties to compress the spring:
                          Then slide on the intake manifold with ease and cut the ties.
                          '88 325is
                          VP UT of Austin Autoholics
                          BMWCCA 380364
                          • Liam
                            • 753
                            /\/\ There you go pics and all.
                            Steel flat washers (under the wave washers, I think I left the incorrect impression in the earlier post)
                            15 ft.lbs. is correct, take them all up evenly a bit at a time though (also looks a little like the gasket could have been in wrong as well)
                            • Hallen
                              • 1008
                              The gaskets are on correctly. There is only one way they will go on and have the injector port gap line up right.
                              It's odd that it cracked. I tightened them down in increments. I started from the center and worked out, kinda like the head bolts. The final tightening with the torque wrench was only a half turn or so.
                              The PO has a history of grossly over-torquing everything so it wouldn't surprise me if the crack had already started before I got the car. Or, it could have just been me making a mistake.
                              1987 E30 325is
                              1999 E46 323i
                              RIP 1994 E32 740iL
                              oo=[][]=oo
