My car is brokded, HELP!
  • StereoInstaller1
    GAS
    • 22679
    Driving home last night I started to have some "chugging", so I stepped on the clutch and the motor died. Bump started it back to life, but then it did it again, repeatedly.
    I limped it home, literally coasting into the driveway.
    This morning, the damn thing started, ran for about 4 minutes, then sputtered and died.
    I am gonna fix it tomorrow, but would love to see some suggestions and ideas.
    So lets hear it...this is the 1st time this car has actually stranded me in years, but this time Jordan is not here to rescue me!
    Luke
    Closing SOON!
    Thanks for 10 years of fun!
  • atomic
    • Jun 2007
    • 5691
    Afm?
    • Beach Bum
      • 466
      I'm thinking a fuel issue mebbe? Intermittent short in the fuel pump circuit?
      If people keep quoting me in their sig, I'm going to burn this motherfucker down.
      • E30Idea
        • Mar 2007
        • 2196
        Fuel filter? Could be all the new gas mixture cleaning your tanks and everything the gass touches.
        ** Lot's of M20 turbo parts for sale.**
        Turn key track car.
        http://www.r3vlimited.com/board/showthread.php?t=222066
        • StereoInstaller1
          GAS
          • 22679
          I think it is eleectrical because the way it died is so suddenly, not like slow fule starvation...so I don't think this is pump/filter.
          Besides, mine is only 5 years old, WTF?
          Closing SOON!
          • twright
            • 705
            1.) Check fuel pump relay
            2.) Check ECU main relay
            3.) Measure fuel pressure.
            This should give you a mountain of info that should make the decision of "where-to-go-next" easy.
            • Devil Inc
              • Jan 2008
              • 802
              TPS sensor? Mine did the same stuff, when it was on it's way out.
              • StereoInstaller1
                GAS
                • 22679
                Main relay.
                Fix'd, but in poking around I caused a vacuum leak.
                Closing SOON!
                • Beach Bum
                  • 466
                  Doh! Well, you probably needed a new hose there anyway.
                  • StereoInstaller1
                    GAS
                    • 22679
                    Yeah, like 30,000 miles ago...
                    Closing SOON!
                    • oekundar
                      • Sep 2007
                      • 964
                      Interesting...nice find/fix.
                      BMWCCA #389756
                      • StereoInstaller1
                        GAS
                        • 22679
                        I have now fixed like 4 cars with main relay issues.
                        You would think I would have thought of that first...
                        The damn thing bucked so hard it was just impossible to believe!
                        Closing SOON!
                        • oekundar
                          • Sep 2007
                          • 964
                          Now when you say fix, I'm assuming that you're replacing the relay no? If so where are you getting the replacements?
                          BMWCCA #389756
                          • StereoInstaller1
                            GAS
                            • 22679
                            The relay is a standard configuration SPST relay: I used a Bosch.
                            These are typically used for foglights, as there are 2 N.O. contacts. I may re-wire using 2 separate relays just for S&G.
                            Luke
                            Closing SOON!
                            • Tree18is
                              • Mar 2004
                              • 2703
                              writeup that relay fix you come up with!
