I've really been trying everything to get my 85 325e running.
So far I have replaced all the things forums tell you to replace, TPS, coolant temp sensor, crank position sensor, AFM, FPR, ICV, main fuel pump, filter and lines and a new battery.
Found out my starter was shot so had it replaced. It failed again 2 months later and they said my alternator was bad too but it was an intermittent failure they didn't spot before. Couldn't get them to help me out on it, so I just did them both myself.
I hooked everything up this morning. I had ordered 6 month warranty parts from bavarian auto recyclers (looked a hell of a lot better than that junkyard starter they had put in for me
) so feel pretty confident that the parts are good.
Well, now I still can't get it to start.
The starter makes a click sound and then immediately starts making a whining noise.
I would suspect the starter itself, but now I can't even push start it. When I push the car and then pop the clutch out with it in 1st gear it locks the rear wheels instead of turning over the motor.
I fear the worst.
Last I drove the car it started under its own power and I drove it 100ft into my garage about 5 days ago.
Any help would be hugely appreciated.
) so feel pretty confident that the parts are good.Well, now I still can't get it to start.
I fear the worst.
