Running auto-x last month I ran into the problem of having the car almost feel like it was hitting a brick wall between 75-90% throttle and its only when Im heavy on the throttle that it cuts out for a quick second then runs fine. I cleaned the throttle body, AFM and replaced a crack air boot between the two, it cleared up for a bit and came back just not as bad.
What would anyone suggest from the described symptoms that could possibly clear this up (i.e. specific places to check for leaks or if its spark, fuel, or air leak)
Im running a tight budget and I would really like to have this solved by next weekend in order to run another auto-x, so I only have the budget and time to change something or fix one of the three fuel, vacuums, or spark. Any help would be greatly appreciated
tia
tia
