M20 starts only after rocking back and forth.
    Hey Everyone,
    First off, hope everyone is well during this current pandemic. With all of this time on lockdown I figured I'd tackle a problem that's been bugging me for a while (to the point I haven't been able to drive my e30).
    For the past year or so I have had intermittent starting issues, that have become progressively more frequent. At times (especially when it's hot out it seems) the car refuses to start, even immediately after shutting it off (say to get gas). The internal lights work fine, but turning the key produces nothing from the starter. I've been putting the car in 3rd gear and rolling it back about 2 feet and it typically fires right up full of vim and vigor. The remainder of the time the car cranks and fires without issue as if it just rolled off the lot. At first the once a week occurrence was just a minor inconvenience, but it got to the point where about 50% of the time it won't start without me pushing it around first.
    I checked the battery and connections, which are fine. After a bit of internet research it seems like it might be the starter commutator has gone bad, which would require the dreaded starter replacement. Any other suggestions that would be causing it? I'm thinking it would be weird to have an intermittent grounding or relay issue that would be solved by moving the car.
    Anyway, I appreciate the help. Stay healthy!
    Brian
    Worn ignition switch? Maybe jiggle the key in the lock and see if it makes a difference.
      Agree with jiggle the key in the lock. If you can't get that to work, I would suspect a bad spot on the starter. One thing to try would be to clean the connections on the battery and make sure the engine ground cable is good.
      2004 525i Manual - 1985 325E Coupe Manual
        When it doesn't start next time, try popping the over off the round diagnostic connector and jump the starter there (black with yellow stripe needs to be jumped with red #14 and #11), make sure the car is in neutral and key on. I've had a couple cars come in for intermittent start in the past, and they would start via the diag port when the key was being a lump. The two repairs ended up being different, though, one was an ignition switch, the other was battery and terminals. EDIT: But both would start via the port.
        john@m20guru.com
        Links:
          Probably not very likely, but if the starter is firing consistently and it wont start could it also be some teeth are damaged on the ring gear? Would make sense that it then starts after moving a bit in gear. No idea how likely that would be on these motors though, but I just bolted on a new flywheel and I thought of this post.
            If jiggling the key in the ignition while holding it in position to start doesn't help, I hate to bring it to you but it's the starter. I had the same issue, heat soaking starter. Replacing it with a known good used one solved it for me. Twice I had to change the starter, because the first time I bought a brand new one, which turned out to be defective. Good luck to you sir.
            '85 Alpine WeiƟ 2-door with m20b30 ground up build
              To test that, dump a gallon of water on the starter.
              The starter on the E36 318 rat I had started sticking hot, and that was the quick fix to get me home.
              The 'moving' thing, though- do you get a 'clunk' from the starter? That COULD be the solenoid popping out-
              but if the contacts inside are dying, then the motor won't spin. But the solenoid will stick 'out'.
              Rocking the engine lets it drop back in, and try again. Had that happen with an old pickup...
              Same fix, though- new starter.
              t
                ^^^or a hammer and socket extension sometimes works. Usually hitting a starter to get it to work is bad brushes.
                john@m20guru.com
                Links:
                  I had a similar issue with my car not starting after I put an OEM exhaust back on it. I bought a brand new starter and still had the same issue. All of the lights and accessories worked no problem but the starter still did nothing. I cleaned the ground to bare metal and had no problems after that. I wish I would have tried that before I bought and installed a brand new starter
                  sigpic84 325e
