ECU Coolant Temp Sensor vs Coolant Temp Gauge Sender
  • ZeKahr
    • Jul 2016
    • 508
    Why did BMW use two coolant temp sensors to send the coolant temperature signal? Do these sensors have different resistances calibrated separately for the ECU and temp gauge or something? Wouldn't they be able to send the same signal to the temp gauge and ECU with just one coolant temp sensor?
    I looked at my Bentley for information on the temp gauge resistance values but could not find anything. It only has resistance values for the ECU coolant temp sensor. Anyone have the resistance values for the temp gauge sender? Specifically for a 1986 325e.
    1986 325e Schwarz (sold)
    1989 325iX Alpineweiß​ (daily)
    Greed is Good
  • tomstin
    • Mar 2015
    • 569
    The best all in one place document I've found. It has many of the resistance values I think you're looking for http://www.verrill.com/car/e30_idlefaq.shtml
    2004 525i Manual - 1985 325E Coupe Manual
    • uturn
      • Dec 2010
      • 1005
      My memory is a little hazy.... I believe the ECU temp sender is two pin type and the temp gauge sender is one pin.
