its the 5th lower radiator hose i buy
  • Faviolosky
    • Nov 2008
    • 154
    ok wtf, the first 2 hoses it was the power steering pump pulley that was cuting the hoses, then i moved the radiator to one sideabout an inch away from the pulley, but later found out that the pump was loose and that it was moving, then the third hose went, Since my steering rack is leaking i have no power steering so i decided to take the pulley out, so no more of that. Yet the hose was broken again by te alternator fan this time, what the hell, the hose seems as it wont clear the alternator, or leave around 1/8" space, which in any hard acceleration it will touch. i dont know why, is the hose that close to the alternator, please help, i dont want either my alternator to damage due to water, or my engine blow because of no water.
  • kronus
    • Apr 2008
    • 13032
    You need to check your motor mounts. Your motor is shifting more than it should during braking and acceleration.
    cars beep boop
    • MDryVur
      • 395
      +1^^^^^^^^^^
      • StereoInstaller1
        GAS
        • 22679
        Originally posted by kronus
        You need to replace your motor mounts and your transmission mounts. Your motor is shifting more than it should during braking and acceleration.
        Fixed.,
        Closing SOON!
        Thanks for 10 years of fun!
        • balooshinakus
          • 511
          Yeah motor and tranny mounts.. I did it this weekend, one of my tranny mounts was in 2 pieces and the other one felt like a gumdrop, pretty dangerous really.
          • kenika65
            • Aug 2007
            • 1336
            +1000 on the mounts also make sure you have the frame mounted hose clamp also.
            1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
            1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
            • Liam
              • 753
              Too long of an Alternator belt?
              Should be a 10 X 965 LA
              I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
              • Faviolosky
                • Nov 2008
                • 154
                Liam you nailed bro, it was the alt belt, too long, and it wasnt even tight. i got the new on and it was still slightly long, so i got a quarter of an inch shorter one, and it was perfect. but it is slightly thicker so it has to wear a little to settle good. so for now my car sounds supercharged:D:D just sounds though, motor mounts are good the engine barely moves, me and my friend tried that first by him on one side and me on the other, rocking it as hard as we could, synchronized of course.
                • kenika65
                  • Aug 2007
                  • 1336
                  Uhhhh First time I have heard that one... LOL
                  Put it in gear with the emergency break on then put it in reverse and see if it moves then LOL that will be a better way to check.
                  • Liam
                    • 753
                    Just one of those things.
