help - leaking valve cover
  • funcrew
    • Jun 2007
    • 1223
    I put a new valve cover gasket in a year ago, and now it's leaking. Any tips on leak-free installation of a new one?
    "If the sky were to fall tomorrow, the tall would die first."
    -Dr. Paul Forrester
    Do I LOOK like I need a psychological evaluation???
  • Aptyp
    • 6584
    I've been reusing valve cover gasket for 2 years now, and still not leaking... Did you replace little half moons on sides of rocker shafts? are you over tightening valve cover nuts?
    • mooseheadm5
      • Apr 2009
      • 375
      I put some RTV (a little) on both the rounded parts of the half moons and the parts that touch the VCG.
      -P
      Moosehead Engineering
      • Liam
        • 753
        I've had a lot of problems with aftermarket VC gaskets (especially the ones with the printed seal stuff on them)
        I know that the OEM is pricey, but I just don't have any leaking problems when I use them.
        And do replace the rubber R/S packing plugs, again the OEM ones don't leak.
        I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
        • funcrew
          • Jun 2007
          • 1223
          OK, I bought a $$$ OEM valve cover gasket and plugs from the dealer. The gasket is this grey waffle-faced jobbie with tons of tiny little sharp burrs all over it. The burrs do not appear to be deliberate - looks like bad QC at the factory. It doesn't look like it would seal well at all. Is this normal, or did I get a bad gasket?
          -Dr. Paul Forrester
            It will be fine. Be sure to throughly remove any old gasket material and torque the cover nuts to spec, working from the center out.
            • TrentW
              • 2815
              Isn't the Elring Klinger brand from Pelican the same as OEM? Grey waffle style I believe. I'm going to change my weeping old gasket when I paint my cover this weekend and was just searching to see if anyone else had this parblem.
                • 34844
                you want the gasket with the sillicone bead built into it. I can't remember the brand.. it's either goetze or elring. Whatever bavauto sells. You can reuse it about 4-5 times before it needs replaced.
                • TrentW
                  • 2815
                  That's the Victor Reinz one that's on my car now and leaks.
