I'm gradually working my way through an 89 325is that spent years sitting. I've replaced quite a few parts with the intent to be able to put some miles on the thing, but I'm encountering a warm start issue that has me puzzled. The car starts right up when it's either cold or hot, but if I let it sit for roughly 30 minutes when it's warm outside, then attempt to start again, it will either not turn over (cranks strong) or won't start without me giving it a little gas on the second attempt.
Yesterday I pulled the plugs when I adjusted the rockers and I have no indications of it running rich, nor does it smell like there's excessive fuel in the oil. I really don't think it's fuel related, but am going to put a gauge on it to verify. Again, the car runs great once it's started and has a stable idle. I've seen similar threads from over the years but nothing that either has a resolution posted, or where the person had quite as many new parts as me.
Below is the list of things I've replaced that would be likely causes or related since I've started working on the car.
-New fuel tank, pump, filter and all new lines. I also installed an inline anti-return valve at the pump. No change here before or after.
-Fuel pressure regulator
-Injectors have been cleaned, rebuilt and leak tested
-Timing belt
-Crank position sensor
-Plugs, wires, cap, rotor and ignition coil
-All vacuum lines and intake boot
-Intake manifold gaskets
-Oil return tube o-ring
-Valve cover gasket
-Blue top coolant sensor
-Throttle switch
-EVAP canister has been removed and ports are capped off
-Zero difference between two good working (and clean) IAC valves
-Battery less than one year old
-New alternator to starter cable as well as fresh ground straps
I've also smoke tested the engine after all of the work above. Found and fixed one small leak I had, but that made no difference.
Assuming the fuel does check out OK I'm going to do a compression test as well. The problem isn't big enough that I wanted to be sure to have all my other work done before I started really focusing on figuring this out.
Anything I'm missing here?
-Timing belt
-Valve cover gasket
-Throttle switch
