Valve springs and top end
  • kickassrocker01
    • 26
    What valve springs are you guys using. I plan on getting stiffer valve springs and want to know what brand and cost effected springs are being used. Also are aluminum rockers necessary or are IE's heavy duty rockers good enough. I have a stock m20b25 and plan to turbo it using mostly stock internals such as stock pistons but want to beef up the top. I also plane to get studs and a mls gasket. Plan to turbo at 10-15 psi and maybe occasionally hit higher in races. I want to be able to rev to redline. What else do you suggest to upgrade. I really want to do pistons but am not able to pull the motor at this time. I know all this could go in the FI forum but I need some answers. I also need to know about oil filter and cooler relocation or can I get around this. Gonna get a bumper mount intercooler.
  • SpecM
    • Oct 2005
    • 4531
    so?
    you don't need upgraded valve springs for a turbo car
    1989 cirrisblau-metallic 325i
    • kickassrocker01
      • 26
      Thats as long as I use stock cam right???
      • Adrian_Visser
        • Jun 2006
        • 2823
        You won't start getting valve float until like 7200rpm or something close to that with the stock I dual valve springs. I mean look at all those people with chipped cars where the redline is bumped to 6900 rpm, they work fine.
        '89 Alpine S52 with goodies
        • dashboardmonkey
          FUCK YOUR WAFFLES
          • Jun 2008
          • 6158
          The worry is breaking the rocker arms.
          -Andy
          • kickassrocker01
            • 26
            That sounds like some extra money in my pocket. So has anyone used IE's heavy duty rockers???
            • E30_fiend
              • Apr 2006
              • 7348
              dont plan on your motor lasting very long with stock internals at 10-15 psi
              • Madhatter
                • Oct 2004
                • 966
                schrick here.
                Just a little project im working on
                - http://www.lse30.com -
                • kickassrocker01
                  • 26
                  What upgrades do u suggest to keep my engine going at 10-15psi.
                  • Aptyp
                    • 6584
                    Head gasket and head bolts, then GOGOGO
                    Been building turbo engine for way too long now, one day I'll finish. Like 5-lug swap, one day. I'm so ashamed.
                    • kickassrocker01
                      • 26
                      Well thats what I was planning on doing mls gasket arp studs new rockers and then turbo it. That should be able to hold 10-15 psi right???? Not driving it real hard every second. I know this is off topic but my car has a eta radiator in it. (87 325is) What is the differences in the radiators??? Like the extra sensor on top. I believe its lighter but does it cool as well???
                      • kickassrocker01
                        • 26
                        I have another question for you guys. When I get the mls which thickness you think I should get. You think I should get a bit thicker to lower the cr a little for 10-15psi??? In the future if the car holds together pretty good I will upgrade the pistons.
