Intermittent Misfire
  • rabbattackk
    • Mar 2021
    • 1
    Hey everyone! Since this is my first project car I'm still learning. I purchased an early m20 and a 1987 e30 sedan separate. I have installed cooling/wiring/etc and got it running and driving. The compression on all cylinders is between 160-175. I have installed and gapped new spark plugs and fresh fuel. When I start the car and the engine is cold it idles nicely and sounds good but after 2/3 minutes of idle it develops a misfire that isn't every revolution but like every 3rd. What could cause this/what should I test before throwing too much money into it.
  • tomstin
    • Mar 2015
    • 563
    Check all the temperature sensors, here is a good reference on idle issues http://www.verrill.com/car/e30_idlefaq.shtml
    Next, check your crank position sensor(s). Depending on which engine, there may be one (i) or two (e).
    2004 525i Manual - 1985 325E Coupe Manual
    • Gregs///M
      • Mar 2012
      • 2459
      Check the condition of your cap and rotor and ignition system. If all looks good, a failing AFM can cause this condition. So can a failing CPS.
      Owner - Bavarian Restoration
      BMW and European Electronics Repair and Restoration
      www.BavRest.com
      My Feedback Thread
      Our Facebook!
      Follow our Instagram!
