eliminating expansion tank
  • LKTe30
    • Dec 2004
    • 151
    I went with an aluminum radiator that wouldn't need the stock expansion tank. Have any of yall eliminated the stock tank and if so how did you route the hoses?
    mike@lookoutdrift.com
  • drift
    • 566
    I'm not sure if this would be appropriate....The only thing i'm aware of is my dirt bike doesn't have stock radiator expansion-tank.
    http://www.kingofeurope.net/2010/
    • Funkmasta
      • May 2004
      • 7185
      aluminum radiator has a built-in expansion tank?
      Joe Funk -- Portland Oregon
      That Guy.
      03 X5. 3 liter obviously.
      • dashboardmonkey
        FUCK YOUR WAFFLES
        • Jun 2008
        • 6158
        Plug the hose to the expansion tank.
        Run a hose from the overflow tube on the radiator to a bottle of some sort.
        -Andy
        • mafoose
          • Apr 2009
          • 34
          Car cooling systems need an expansion tank.
          If you're good at fabrication, just make a tube with welded ends, a fluid "pickup", and a level sight.
          Something like this:
          Make sure that the fitting has a tube to pick up from the bottom, or put the fitting at the bottom, as these are for overflow and recovery.
          • dashboardmonkey
            FUCK YOUR WAFFLES
            • Jun 2008
            • 6158
            ^Perfect
            -Andy
