M30 Swap No Power
  • hp13
    • Sep 2021
    • 39
    M30 Swap No Power
    Hi, I’m working on an M30B35 swap on my 1984 318i and I’m at the point where I’m wiring everything in. I’ve got the C101 connected and everything plugged in (I think) but when I go to start the car theres no power at all. No lights turn on in the dashboard and theres no cranking. One thing that does work is when I jump the fuel pump relay on the engine harness I can hear the fuel pump running. Am I missing a ground somewhere as I only have the harness grounded at the strut tower at the moment? I also haven’t connected that small connector beside the ecu yet and before the swap there was no problem with the ignition. Not sure what the problem could be any help is appreciated!
  • downforce22
    • Aug 2009
    • 3193
    did you ground the engine to the chassis?
