will an m5 trans work?
  • coolasacuc
    • 383
    can I use an e28 and e34 M5 trans for an m30 in an e30? if so, what modifications are needed (crossmember, bushings, linkage etc.?
  • JoeMadoo
    • 936
    just a bigger wallet...
    '86 E30
    '05 E53 X5
    '72 Firebird
    '10 Prius
    '03 Tundra
    • mooseheadm5
      • Apr 2009
      • 375
      You can use one, but you don't want one. Trust me. However, if you do want one and can afford to have one rebuilt, I have a core for you.
      -P
      Moosehead Engineering
      • Jean
        • 18228
        Care to explain why he shouldn't use one?
        • kronus
          • Apr 2008
          • 13031
          Whatever his reason, Funkmasta agrees with him. I've seen him grumble about the getrag 280 before...
          cars beep boop
          • mooseheadm5
            • Apr 2009
            • 375
            It is actually a pretty fragile box. It does not take kindly to cold shifts, hard shifts, shifts, use, etc. The synchros are made of peanut brittle and get destroyed very easily. It is only sort of close ratio and not suited for the M30 powerband. Most of all, it is rare and expensive, and expensive to rebuild (need special tools and skills.) You can buy a good used one for about $1500. A rebuildable core is worth about $500. A Getrag 260 is about $200-$300 and a 265 is only a couple hundred more and can take whatever power and abuse you have to offer. To boot, the 265 was used behind an S14, so a direct bolt in trans brace is available.
            -P
            • oli335i
              • Apr 2009
              • 1
              Got one at the back of my m30. Its near new and the only one I had, so don't know about it being fragile (yet) and can't compare to other types. Works fine for me though, no issues with it.
              Its coupled to a 3.15 LSD.
              1st gear up to 45km/h
              2nd to 95km/h etc
              • coolasacuc
                • 383
                wow! well after those inspiring posts, i'll be sticking with 260 for sure.
                AND DAMN THOSE ARE EXPENSO!!!
                • Lurker27
                  • 821
                  Were the 280s in anything other than M5s? I was ordering some stuff and plugging around on realOEM and it seemed to think a 1991 535i could have one...better double check my casting I reckon.
                  '89 335is +turbo
                  • coolasacuc
                    • 383
                    91 535 = 260/5
                    • Jean
                      • 18228
                      Are you sure? 91 should have a 260/6
                      • mooseheadm5
                        • Apr 2009
                        • 375
                        280 is M5/M6 only, but it kinda looks like a 260 from the outside.
                        -P
                        • Lurker27
                          • 821
                          I am almost certain it is a 260, just thought it was weird on realOEM.
                          '89 335is +turbo
                          • BDK
                            • Jul 2008
                            • 684
                            I personally like the 280 myself, I have had all 3 and really liked the 280 in my E28 M5....
                            the main difference between the 260 and 280 is that the body of the trans is abit longer, maybe 1" TO 1 1/2" longer...
                            • Jonsku
                              • Oct 2004
                              • 566
                              Doesn't 280 have the cooling fins also?
                              Use 260/6, it's the most durable box which has ever been bolted onto M30. 262/5 or 265/5 are expensive, though straight bolt-on's.
                              If you're going with 280 you need different driveshaft, mounting bracket etc etc..
                              - E34 M5 (x 2) -
                              - E30 V8 Cabrio "Kylpyamme" -
                              - Alpina D10 Touring #33/94 -
                              - E46 318i Touring -
                              - Toyota Hiace 4wd -
