M30b35 swap: just a few questions.
Pretty much exactly what happened to me. Amazing how much time things take with college and a job. And no money.
This will help with the wiring:
From what I remember you need to splice in a wire from the e30 c103 plug into the c101 (or x20 as I think the 7 series ETM refers to it as)Originally posted by LJ851I programmed my oven to turn off when my pizza was done, should i start a build thread?
FeedbackComment
Read this, I posted the wiring side of things for the guages on another M30 thread.
RavYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
If you have bought items from me, please leave feedback below.
If you are a BUYER, Check My Feedback.:up:
http://www.r3vlimited.com/board/showthread.php?t=183860
Check out my Euro Build Thread
http://www.r3vlimited.com/board/showthread.php?t=215557Comment
What temp sensor are you using? When I did my B34 swap I had to use the M42's temp sensor.Comment
Thanks for the info rav and chad. I'm still a little lost, but it's a good start and excellent information. Now for my dumb question of the day. Where do I find the c103 connector?
I'm using the sensor that came on the engine from the '88 735i. Since I'm using the engine harness from th 7 as well I figured it would be fine. Been wrong plenty of times before though.Searching...Comment
FeedbackComment
Facelift wiring mods (these apply to those with a facelift shell) - the engine will run without doing them, but for everything to function correctly, the following are needed;
To get the 'economy swingometer thingy' working you need to swap pins in the M30 loom:
Pin 3 (black and white) and pin 8 (black and purple).
To get the electric windows and sunroof to work with the doors shut and for the heater blower to work at all you need to connect the black and green wire from pin 15 on the E30 C101 to a small spade connector on the starter motor.
rev counter?
Prefacelift mods (these apply to those with a pre-facelift shell);details
C104/C101 rev-counter & econometer modsYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
IIRC the large diameter green wire on c103 is what you are after. been a long long time though since I traveled down that road... f&*king c101/c103 early chassis harness BS.Comment
Now I'm confused. I don't mean to be a dumb ass, but I have no idea what the last bit of your post means. I'm working on a 1987 325is. It's pre-face lift, so could you clarify what c104/c101 rev-counter & econometer means.Facelift wiring mods (these apply to those with a facelift shell) - the engine will run without doing them, but for everything to function correctly, the following are needed;
rev counter?
So I connect the green wire from the c103 to the wire from pin 9 on the engine side c101 to get the tach to work?
Thanks for the help so far, I know it must be annoying to have to try and hold my hand through this, but I'm more than a little clueless here.Searching...Comment
Search for my old thread, it's all in there as well as in Franks guide.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Got this out of Frank's thread. Does anyone know what the part number for this sensor is?For the coolant sensor installed on the engine, please use the M20 sensor. You can either remove it from your M20 engine or buy a new one. For compatibility reasons, the M20 temperature sender must be used.
I got on pelican and it has this sensor listed as "water temperature sensor"
13-62-1-357-414-M14
http://www.pelicanparts.com/cgi-bin/...2D%39%31%29%20
They also have this one listed as "temperature sending unit."
12-62-1-710-512-M323
I'm thinking that this is the reason that my temperature guage won't work. I just need to know which of these to order. I read somewhere that the one with the brown top (the second one I listed) is the part that I need, but I was hoping that someone on here could confirm this or let me know specifically which temp sensor I need.Searching...Comment
