Ok. So if i buy the 3.5 out of a 735i car. What transmission will bolt up to it. I want a 5-speed but someone told me that they only made automatic and if thats the case than no 3,5 for me. Let me know thanx.
Tranny Talk
Tags: None
the bell housing for the m30 was shared between the m10, m30b34, m30b35, m30b33, m30b33, m30b28, s14, and the list goes on
you can get a 5 speed from any of them, and even the 4 speed from my e12 will work.
your trans choice depends on what your looking for, there are close ratio trans, dogleg CR, regluar trans, the e30m3 CR trans and so on
i'm sure ian or someone else will pop in with all the 260/5 and 265 numbers stuff
this has been covered a ton and searching is your friend, your semi local so ill go easy on you ;) -
Best choice for you would be getrag 260/5 (E28 535) or getrag 260/6 (E34 535). There should be plenty of those 4 sale quite cheap.- E34 M5 (x 2) -
- E30 V8 Cabrio "Kylpyamme" -
- Alpina D10 Touring #33/94 -
- E46 318i Touring -
- Toyota Hiace 4wd -Comment
pretty much any trans tat came off of any of the motors i listed above will workComment
