B35 on '87 eta wiring culprits ?
  • drift
    • 566
    Got the motor installed, cranks up, but it won't fires up.
    (It's B35 off of AT , 87 eta 5 speed) Both cars were running fine before swap.
    All Spark plugs are 'dry' ( no fuel ? already swapped the fuel lines : inlet / outlet)
    Here are the quick cell phone pictures (the wiring woes) below.
    Anyone knows what's the culprit?
    http://www.kingofeurope.net/2010/
  • kronus
    • Apr 2008
    • 13032
    Same as any other motor, check for spark and fuel. Does the fuel pump turn on? Do you have spark?
    cars beep boop
    • drift
      • 566
      kronus,
      I only heard click 2x in the engine bay , when i turn the key on ( before crank).
      But, i didn't hear " hummm" or " zeeee" noise from the fuel pump as usual.
      Did i miss some Relay or Sensor ( see my quick picture above) ?
      And, No spark so far.
      • E30SPDFRK
        • 5705
        Check that the crank position sensor and the tach reference sensor aren't backwards. Both are the same plug and the engine won't run if they're switched.
        Byron
        Leichtbau
        • drift
          • 566
          AFAIK, the CPS is located right on the front crank pulley ( idk where it goes to, further up).
          Which one is the Tach Reference Sensor ? Is it same as TPS ?
          Btw, I'm using all B35 wiring in the engine bay, and still have 87 eta wiring from fuse box (C101 plug ?) inward.
          I wonder if you have some pictures or link ? Thanks
          • E30SPDFRK
            • 5705
            The reference comes from one of the spark plug wires. Both the CPS and the reference signal connect to the harness towards the front of the injector plug cover thing on the valve cover side. Both are 3 pin plugs.
            When you say you heard clicks from the engine bay, do you mean the starter was clicking and not turning the engine, or were they coming from somewhere else?
            Byron
            Leichtbau
            • drift
              • 566
              That Click - Click always there when i turn the key on ( both on dash or in engine bay) as i can feel the tap with my hand on the fuse box ( relays?)
              The engine always cranks nicely, but it won't fires ( checked all spark plugs, are dry) .
              • E30SPDFRK
                • 5705
                The click sounds like the main relay going about its business- perfectly normal.
                Check to make sure you have fuel and spark. Pull the fuel return line and turn the key on a few times and make sure fuel comes out. Then pull a spark wire while cranking the engine and check for spark.
                We'll go from there.
                Byron
                Leichtbau
                • Doughnut
                  • Oct 2007
                  • 869
                  Do you have power 12v at green/violet wire on engine harness side? You must have a signal from that wire to get fuel.
                  ///Monstrosity. (OO≡≡[][]≡≡OO)
                  Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
                  • drift
                    • 566
                    After a few hours of Trials & Errors ....
                    See the picture with colored-circles above:
                    Blue : to + battery terminal @ firewall
                    Pinks: to - Ground
                    Brown: 5 prong Relay
                    Violet : 4 prong Relay
                    That was LOUD, it cranks & fires up !!
                    Thanks alot guys !
                    • BonnschE30
                      • Jun 2008
                      • 295
                      care to label the rest of the colored circles for those of us interested and just for future reference?
                      • drift
                        • 566
                        I guess... the rest of them (circles) are for Automatic car ?
                        Since i'm running 5 speed, but i will get to it if needed.
                        • BonnschE30
                          • Jun 2008
                          • 295
                          my bad shoulda paid more attention when you specified it was an auto. never mind then, I just want to do an M30 swap sometime soon and am into getting as much info ahead of time as possible. thanks tho!
