sucks you should ave went SR.LOL
So close, I can taste it. mmmm
Update:
Got a new head from ecartoys (Thanks!) and it runs! Little hic-up though. It will not idle no matter what do. No vacuum leaks that I can find. Running the m20 harness. Swapped icv, same result. I have to give it about 1/4 throttle for it to stay running at ~900-1000 RPMs.
Any thoughts?Comment
I was told to look into the AFM adjustment as well. Thanks for the tip.
Yes I am running an o2 sensor. The m20 one if that matters.Comment
FIXED.
Swapped out the harness from the m20 to the m30 and it idles, revs, the works. With the swap, I changed to the auto TPS. It doesn't seem to run as smooth as it should, but Ill chalk it up to the o2 sensor not being hooked up.
I'm not saying the m20 harness will not work for the m30, but if you have access to an m30 harness (whether it be auto or manual) it is much easier to use.Comment
Good job! I like the m30 harness myself, it fits perfect and is made for this engine :)Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Now he tells us LOL!
I'm experiencing your original problem atm now, it has the same problem asif the temp sensor for the ecu is unplugged... Maybe it's faulty?///Monstrosity. (OO≡≡[][]≡≡OO)
Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
original problem? If you are talking about it cutting out, I never figured that one out. A valve and rocker broke before I could investigate further.Comment
Well, it's kinda different...
It's fine from cold start, but once you turn it off then come back in say 20 mins it will idle rough and miss and carry on for a little while before it smooths out and becomes drivable again.. I actually have to sit there and rev till it smooths out which is really shit when your in a busy carpark, street etc...
I believe it has something to do with the temp sensor for the ecu.///Monstrosity. (OO≡≡[][]≡≡OO)
