Swapolocalpyse has begun.
  • kronus
    • Apr 2008
    • 13031
    149K '86 535i 5spd, with full and comprehensive records of all services. Rear ended and pushed into the car in front :(
    Pristine interior, super clean inside and out before the crash. Unfortunately, currently the radiator is wrapped around the engine fan, so it does not start (although I am legally assured that it will). Clutch is two years old.
    Going into a '87 325e with 140K on the clock.
    Swap is scheduled for the last week of August. :drink:
    Thread where I asked many many questions about this swap: http://r3vlimited.com/board/showthread.php?t=123097
    The info will get updated and corrected as we plow through it.
    cars beep boop
  • lennon
    • Jun 2008
    • 1416
    rust the hood and drive that sucka
    • RickSloan
      • 2401
      let the fun begin!
      any pictures of the car from the PO before the crash? im digging the wheels and the hood on a 5er
      Need Illustration or Design work? www.robbiebyerly.com
      • Danny
        • 14216
        So this should be done in... 4 years?
        • kronus
          • Apr 2008
          • 13031
          Get a haircut.
          cars beep boop
          • Danny
            • 14216
            I been had a haircut.
            • kronus
              • Apr 2008
              • 13031
              Get a yob, then.
              I'm putting together a $$$ Pelican parts order. What all should be done while the motor is out?
              So far:
              intake manifold gaskets x6
              oil filter kit
              valve cover gasket
              exhaust manifold gasket x2
              water pump + gasket
              thermostat gaskets
              trans input seal
              trans output seal
              selector rod seal
              questionable:
              Thermostat?
              Thermostat housing?
              Belts?
              What sensors should I need?
              E30M3 trans mount will work?
              E32 headers will mate to e30 325i downpipes?
              cars beep boop
              • Danny
                • 14216
                I been had a yob too.
                • kronus
                  • Apr 2008
                  • 13031
                  Get an M42 tarbo :o
                  cars beep boop
                  • yert315
                    • 2734
                    Originally posted by kronus
                    So far:
                    oil filter kit
                    valve cover gasket
                    water pump + gasket
                    thermostat gaskets
                    trans input seal
                    trans output seal
                    selector rod seal
                    rear main seal
                    timing cover gaskets
                    questionable:
                    Thermostat?
                    Thermostat housing?
                    Belts?
                    replace the thermostat, its fairly cheap. The housing will be fine, it's metal.
                    I would suggest replacing the accessory belts.
                    e30 temp sensor (for the gauge)
                    I believe so, depending on the transmission used.
                    no, they have different flanges.
                    • kronus
                      • Apr 2008
                      • 13031
                      Originally posted by yert315
                      rear main seal
                      Motor has low miles, doesn't leak out of rms. I don't want to take off the flywheel and timing cover :|
                      This one?
                      It's a Getrag 265, afaik.
                      Really? People have told me that it will work....
                      cars beep boop
                      • chadthestampede
                        • Jul 2008
                        • 3601
                        What mounts are you using?
                        Originally posted by LJ851
                        Feedback
                        • wildstoats
                          • Sep 2007
                          • 896
                          Depending on the availability of a good driveshaft shop (or your own fabrication skills) I would consider sourcing a g260. I'm currently in the process of trying to get my g265 to work and it's just not happening with any combination of stock parts that I have tried so far. I'm going to have to actually take the entire car up to a shop and have them fab something custom for me. If you use a g260 you can just use a 325e "big-guibo" driveshaft and be done with it. To the best of my knowledge the only thing the g265 has going for it is that it's slightly beefier and has a removable bellhousing. I just wanted to let you know because I kind of got blind-sided by the issues raised when trying to use a g265.
                          • kronus
                            • Apr 2008
                            • 13031
                            So the eta driveshaft won't work with a g265? :/
                            Is length the issue?
                            cars beep boop
                            • wildstoats
                              • Sep 2007
                              • 896
                              Yeah the eta driveshaft is too long by a couple of inches. A stock e28 driveshaft is also too long fyi. As far as I know there is no "bolt on" driveshaft solution when using the g265 but if someone has one I would love to hear about it.
