Swapolocalpyse has begun.
  • kronus
    • Apr 2008
    • 13032
    I the 265 that much longer than a 260? That's disappointing.
    Have you looked at e30 auto driveshafts? You may be able to mix and match fronts and backs until something works.
    As it is, I'm still not sure if I have a 265 or a 260/6.
    cars beep boop
    • wildstoats
      • Sep 2007
      • 896
      Yeah it's not a lot longer but it's a couple of inches. Just enough that it won't work. The easiest way I have found to tell them apart is the angle on the mounting forks. Picture the transmission bolted in place under the car. If the mounting points point straight down then it's a g265 if they are angled in towards the transmission it's a g260.
      • Jean
        • 18228
        Picture of 260/6 for your reference kronus.
        http://www.briangt.com/gallery/album...5462.sized.jpg
        http://www.briangt.com/gallery/album...5464.sized.jpg
        • Jean
          • 18228
          I would at least replace the easy to reach gaskets, and check the back of the head as well. This one tends to leak...
          http://www.briangt.com/gallery/album...2/IMG_7017.jpg
          • kronus
            • Apr 2008
            • 13032
            Jean, your engine is incredibly clean.
            E28 Transmission Information from the E28 Bentley
            528e
            1982: getrag 260/6
            1983-1988: getrag 260/5
            533i
            1983-1984: getrag 260/5
            535i
            1985: getrag 265/6
            1986-1988: getrag 260/6
            Gear Ratios
            Getrag 260/5
            3.83
            2.20
            1.40
            1.00
            0.81
            3.46 reverse
            Getrag 260/6
            3.83
            2.20
            1.40
            1.00
            0.81
            3.46 reverse
            Getrag 265/6
            3.82
            2.20
            1.40
            1.00
            0.81
            3.71 reverse
            cars beep boop
            • kronus
              • Apr 2008
              • 13032
              Hooray! I appear to have a 260/6 and not a 265!
              cars beep boop
              • yert315
                • 2734
                in that case, use the front half of the e28 shaft and rear half of the e30 drive shaft. It will mate up perfectly.
                and regarding the headers/down pipe issue. The e30 down pipe flanges are 3 bolt and the e32 ones are 2 bolt. You may be able to get away with using the e28 headers to e30 down pipes. I don't know if they will mate up, but they are both a 3 bolt flat surface flange.
                • kronus
                  • Apr 2008
                  • 13032
                  Good to know. What about E34 headers?
                  cars beep boop
                  • LowR3V'in
                    • 4209
                    You can use your stock driveshaft if it has
                    the large flange. Use the b35 manifolds. They flow more. :)
                    • yert315
                      • 2734
                      e32/e34 headers are the same. Basically the b35 headers have the two bolt and b34 has 3. Look at the picture lowr3vin' posted, the one on the right is a b34 header.
                      If it helps, I went with the b34 headers for two reasons. 1.) the e24 635 had a down pipe that reduced into a single 2 1/4 outlet, which was perfect because I was planning on having a single pipe exhaust. 2.) I plan on going turbo later and the flanges for the b34 are ideal for creating a manifold adapter.
                      • E30SPDFRK
                        • 5716
                        I did this. It did not work.
                        I had to have the e28 front half shortened a bit. There is a driveshaft place near me that did it for $90 and it is perfect.
                        As for the downpipes- if you use e32/4 manifolds, the 325i downpipes will line up correctly, they just wont bolt together. It is a fairly easy weld job to mate the 2 together, any good exhaust shop should do it for under $200.
                        Byron
                        Leichtbau
                        • kronus
                          • Apr 2008
                          • 13032
                          Went to the car, got photos
                          Notes for the photos:
                          1279: large, empty toolkit
                          1281: driver's seatback frame is bent... backseat is pristine
                          1283: ugliest headunit on the planet. It claims to be 52Wx4, though.
                          1292: more seat carnage
                          1296: shit's all crunched up into the radiator
                          1297: HYDROBOOST!
                          1303: getrag 260/6?
                          cars beep boop
                          • Jean
                            • 18228
                            Looks like a b34 with a 260/6 :)
                            • kronus
                              • Apr 2008
                              • 13032
                              How's this look?
                              cars beep boop
                              • Jean
                                • 18228
                                I would also inspect all the hoses and such on the engine as well. ICV to manifold hose, manifold to the fuel evap valve. Also oil filter housing gasket, front/rear timing gaskets, or seals also. Also the other shifter component, the white ring that sits in the shifter carrier, they are usually worn out.
