Cleaning up and old harness is fun
  • Jean
    • 18228
    Not sure if this will help anyone, but I took a bunch of pictures as I removed a harness from a junked 535i recently as I was not happy with the harness I had on my hands with cut wires.
    Now I have two harnesses to play with, one with a 20 pin connector and one with a 25 pin x20 connector. I believe somewhere in 90/91 bmw switched from the 20 pin to the newer style 25 pin round connector. So keep that in mind when you shop for a harness for your e30m30 swap. The pin outs for the 20 pin harness are easy to find and more common vs the 25 pin.
    If it helps here are more pictures for reference on where what is connected. I took these for my own reference in case I forget lol.
    This website is for sale! briangt.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, briangt.com has it all. We hope you find what you are searching for!
    Ignition coil and two ground connections.
    Automatic harness has these additional plugs and sensor
    Automatic harness TPS is different from the Manual harness TPS
    What a mess!
    ICV on the top, Oil pressure switch on the bottom
    AFM
    Top one is the fuel evap valve thing, then oil level sensor, Round 4 pin I am not sure, is that O2 sensor? and then 2 starter wires
    Fuel injector ends
    ECU end with the extra plugs for automatic tranny
    Removing old loom/tape, most of it was easy to clean as it was dried up/cracked.
    ECU end
    Center section
    Temp sensor and tps ends
    Most of it done
    Starter ends, oil level sensor, and the round o2 4 pin
    I am not quite sure what to do with the injector ends just yet....
  • Holland
    • Nov 2008
    • 7178
    I'm sure that will be very helpful to quite a bit of people. Good work.
    Originally posted by DEV0 E30
    • drift
      • 566
      Jean, On your picture # 3 ( two Brown wires) , what harness is that ?
      http://www.kingofeurope.net/2010/
      • E30SPDFRK
        • 5694
        Wow, looks good. Did you take out any wires or just re-wrap and neaten it up?
        Those injector clips are such a pain in the ass, lol.
        Byron
        Leichtbau
        • Jean
          • 18228
          drift - that is part of the automatic e34 535i harness, it goes to a temp sensor that sits inside the e34 ecu/junction box.
          e30spdfrk - i have not removed any wires yet, I want to make sure it works first before I remove those extra plugs for the automatic tranny stuff.
          • Jean
            • 18228
            Looking at this graph below :
            My adapter goes like this. e30 84 318i plug (left side) to e34 round 20 pin plug (right side)
            1 to 1 = D+ alternator
            4 to 4 = FT coolant temp transmitter
            6 to 6 = power with ignition turned on fused
            7 to 13 = fuel pump
            8 to 18 = power while starting
            10 to 7 = power with ignition turned on unfused
            16 to 5 = oil pressure
            17 to 11 = Service indicator wire
            The following two I have no idea if it even would make any difference connecting since I don't have a check panel.
            2 is not used for static oil pressure or can be connected to 2 on the e34 harness?
            15 is not used for dynamic oil pressure or can be connected to 10 on the e34 harness?
            Then I think there must be a wire that goes from the e34 harness to the cluster bypassing the c101 connector? That could be PIN #9 (or 14 below as black/white) from the e34 harness, small black wire. Pin 8 on the E34 side could be MPG?
            Tomorrow I am going to drop the glove box and figure out where this wire is, maybe I'll start disconnecting wires until my tach or speedo stops working?
            On the E34 side of the harness the following pins are not used
            3 - blk/white
            8 - blk / purple (this could be MPG lead?)
            12 - grey (check engine light)
            14 - blk/white (possibly used for speed input for cluster?)
            15 - brown/black (runs unloaded relays?)
            16 - yellow/white (air bag)
            17 - white/purple
            20 - brown/yellow
            • drift
              • 566
              Thanks Jean, I have the same e34 20 pin harness on '87 eta 5 speed,....Btw, does the (2 brown wires) harness ( ^ your pic # 3)needs to be connected to ?
              • Jean
                • 18228
                I don't think so, I am thinking #12 is used with #10
                http://www.realoem.com/bmw/showparts...52&hg=12&fg=35
                But I'll have to dig through ETM to figure this one out, unless someone can confirm?
                It seems that both AUTO and 5speed cars have that blower fan and temp switch listed under realoem, but googling their part numbers I can't confirm their function.
                Just want to say Thanks to all who posted info on how to replace the a/c or heater fan. Great news I was able to replace mine today and it now works squeak / whine free. 1st I thought it was the Control Unit Box fan, and was crazy enough to buy one from BMW Canada for about $230.00 last fall. Well
                • drift
                  • 566
                  Ok, been wondering if that was the culprit of this problem : http://www.r3vlimited.com/board/showthread.php?t=102463 ??
                  • Jean
                    • 18228
                    No idea..
                    • StereoInstaller1
                      GAS
                      • 22679
                      Jean, when you moving to Seattle?
                      Closing SOON!
                      Thanks for 10 years of fun!
                      • Jean
                        • 18228
                        If I had a perm. IT job there lined up I probably would... but moving now wouldn't be a good idea since UI don't transfer....
                        • Jean
                          • 18228
                          So here is my adapter pin outs... left side is 84 318i rectangular plug, right side is round 20 pin e34/e30.
                          See this thread on the 3 pin connector above the glove box - http://www.r3vlimited.com/board/showthread.php?t=146117
                          1 goes to 1 d+
                          2 goes to 2 oil level static
                          4 goes to 4 coolant
                          6 goes to 6 power fused
                          7 goes to 13 fuel pump
                          8 goes to 18 power on start
                          10 goes to 7 power not fused
                          15 goes to 10 oil level dynamic
                          16 goes to 5 oil pressure
                          17 goes to 11 service indicator
                          Now here is where I am finding extra wires on the 20 pin C101 side that possibly need to be connected as well, maybe to the 3 pin connector?
                          8 pin from the round 20 pin - possibly mpg lead to the yellow/white on the 3pin connector above the glove box (black[tach], green, yellow/white[mpg])
                          9 pin from the round 20 pin - possibly tach?
                          14 pin from the round 20 pin - possibly tach again?
                          For those who have done this swap into an early E30, did you do anything with PINS 8, 9 and 14?
                          What about the 3 pin connector above the glovebox? Did the car start w/o connecting the Green wire on the 3 pin plug?
                          Thank you!
                          • gregslow318i
                            • Sep 2007
                            • 1918
                            I need to go back and look at my notes for the adapter but in the mean time I am 100% sure that extra plug for the last pic is the o2 sensor plug (round 4 wire plug) was the harness from a 5 speed car? also the plug and the sensor in the dme box is in the same line as the oil psi switch (same on my m60 harness) I willing to bet the dme reads reistance on off the sensor in the box and uses that to switch from warm up to closed loop. but I am not 100% sure on that
                            looking for a e30m50 swap harness adapter pm me $150 shipped
                            email nitroman12@gmail.com
                            • Jean
                              • 18228
                              This harness was from an automatic car. My other one was from a 5 speed. I think Frank used exactly the same harness as this in his b35 swap and didn't have to do anything with the extra 3 plugs on the engine harness side.
                              When you say it's on the same line as the oil psi switch, what do you mean?
