ok here is my issue
i swapped an e32/e34 b35 harness onto my b34 i will be doing a write up later after i have everything worked out.
my problem is im idling super high. I was at 1500 and played with the tps to get it down to 1100. When i rev it comes back down very slowly but steadily slow. The idle is no erratic at any point. The harness did have auto tps and i swapped a manual plug on to connect to my manual tps. I now got a auto tps and im going to swap the plug back to see if this is the issue. I swapped the icv and both did the same thing.
ANY THOUGHTS?
also my temp gauge is not working. I think its cause my cluster is motometer and the ecu and sensor are now vdo? So will a vdo gauge fix my problem? When the car is on the gauge gets a signal just doesnt read the temp after that.
tia
ANY THOUGHTS?
tia
