S14 swap in to 325is
  • e30s52
    • Oct 2007
    • 5235
    but it will sound nice. swap the exhaust over too.
    Buzzy little 4 cylinders lol. They sound ok but I wouldnt say nice.
    www.gutenparts.com
    • Farbin Kaiber
      Lil' Puppet
      • 29502
      Ok, so it won't sound nice, but it will sound better than a totaled e30 m3 must.
      • avery0829
        • Dec 2008
        • 793
        it's a straight swap, pull the engine/trans/driveshaft, rear diff, and install them into your non-M e30. Then swap radiator/cooling system into car, then hook up wiring and bam.
        Okay, thanks for the help. Also are you saying the harnesses would be a straight plug and play?
        • avery0829
          • Dec 2008
          • 793
          Billstien struts on IE3 springs.
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            No, it's not plug and play. You will need to make or buy a connector.
            • avery0829
              • Dec 2008
              • 793
              Alright, well I guess I'll check that out. Thanks
              • e30polak
                • 6136
                Only positive to putting the s14 vs. 24v will be the handling. The lighter 4 cylinder will make the car much more neutral.
                I'd put that motor in a 2002 instead, like Blunt did. Then you'd have a car that's just as fast and handles way better ( with the proper suspension of course) than a 24v car! :twisted:
                INSTAGRAM: @UNDR8D_EMPIRE
                • avery0829
                  • Dec 2008
                  • 793
                  I like my E30 though :)
                  But a S14 2002 would be baller.
                  • 87-325ic
                    • Apr 2006
                    • 1198
                    its an e30-> e30 swap, just swap all the subframes, and harnesses, shouldnt be too hard.
