putting an m60 in my e30
  • e30conv
    • 79
    Hey everyone, im trying to gather parts for my 89 325i convertible to convert it to a v8. I already have the motor from my 94 740i and actually still have the car too. what am i going to need to pull this swap off, what else should I grab from the 740i before i get rid of it? I am not it a rush to pull this off but would like to start getting everything i need. Any help would be greatly appreciated thanks
  • Thehemiman
    • Apr 2009
    • 533
    Where are you in Princeton? I'm in Westminster about a 1/3 of a mile from the Princeton line. It would be cool to check out the progress of the build in person...
    Sorry for the unhelpful post.
    1988 325i Vert
    1991 318is Slicktop
    • george graves
      • 20003
      You'll need some of these:
      And a "can-do" attitude, cause no one here has a shopping list of what you'll need.
      Originally posted by Matt-B
      • Jean
        • 18228
        Lot's of custom work to make it happen, and you pick a vert? doh.
        • Dominic49
          • Feb 2007
          • 1373
          meh i had a pretty good list going.
          • george graves
            • 20003
            By all means...
            • vr2jetta
              • 460
              I would love to see this! Fuck your small block 350!
              • gregslow318i
                • Sep 2007
                • 1918
                yeah if fits but I have just over 4k in parts and I did all the work my self, a few places make motor mounts, but not worth the my in opin, if you got a welder and time you can do it.
                looking for a e30m50 swap harness adapter pm me $150 shipped
                email nitroman12@gmail.com
                • rafiki
                  • 245
                  not to bring this back from the dead or anything. but how much do you guys think an m60 is worth if i found one? there is one for sale locally and was wondering what a good/ bad deal was...
                  from his post...
                  "28K mi 1994 BMW 840/740 M60 4L V8 engine with engine harness, engine/trans/tracs computers, power steering, alt, starter, injectors, throttle body and a bunch more. "
                  he said bmw replaced the long block 28k miles ago...
                  • Be30mer
                    • Jan 2010
                    • 1121
                    from his post...
                    if bmw replaced the long block it was probably because the m60 recall due to the engines losing compression from the contents of the gasoline reacting with the block. so the engine is most likely an m62. if its up for $2k or less, Id be all over that.
                    You are lucky your Dad didn't pull out and leave you on the passenger side seat.
                    • rafiki
                      • 245
                      ok thanks, whats the difference between the m60 and 62
                      • Be30mer
                        • Jan 2010
                        • 1121
                        m62 have cylinder walls made of a different metal, larger displacement, slightly higher power output. basically an m60, but better
                        • Jb325is
                          • 2137
                          Not likely.. alusil m60's are what replaced the Nikasil m60's that failed. Swapping from an m60 to m62 is do-able, but it requires a lot of m60 parts to be transferred over to the m62 and is not something that BMW is likely to do under warranty. I'd be wary of the motor being replaced 28k miles ago also, I think that recall expired in like 2001
                          - '88 m54 coupe
                          <3
                          • Be30mer
                            • Jan 2010
                            • 1121
                            u sure? my dad had a 1995 540i and it started losing compression at like 80k miles, so he took it in and they replaced it with (what I thought was) an m62 in 2000. no way to check now, the car is sold and long gone
                            • rafiki
                              • 245
                              the guy goes on to say
                              "This engine has the updated alusil cylinder liners due to the original nikisal issue; BMW replaced the whole long block 28,000 miles ago. This engine is nice, even the magnesium valve covers are perfect. E-mail me with any questions or offers. "
