M30 motor using M20 loom/harness?
  • Paz
    • Jan 2010
    • 10
    Hi guys, first post for me!
    I stuck an M30b35 into my 1990 318iS the other day and i used an M20 325i Facelift wiring loom/harness to wire the engine in. After cutting back a few sheaths the M20 loom/harness plugged in a treat and everything seemed to match up nicely with the M30.
    Tried to start it today with no luck. The only thing that initially happened was the starter motor gear engaged with the teeth on the flywheel but it didnt spin the engine over. I then hooked up a 12v source from the battery to the main contact on the Starter motor and this allowed me to turn the engine over using the key... I ran out of daylight after that but it doesnt seem like much is going on with the motor..
    Has anyone used the M20 loom on here to run their M30? Did you have to do anything in particular to get it running? I have a feeling that perhaps i dont have all of the lives i need hooked up at the battery but i cant find any more within the loom, there are 3 ring connections wired up to my +ve terminal... I'll also be checking the earth strap on the side of the engine to make sure its good also..
    Thanks, any help appreciated.
    • 34844
    I know at least one person has done it but I can't remember who.
    • kronus
      • Apr 2008
      • 13032
      George Graves
      cars beep boop
      • chadthestampede
        • Jul 2008
        • 3601
        I used one, it worked great. Just had to extend the afm and fuel level sensor wires. I used the m20 cps as well. And the m20 alternator. And power steering pump. Just an fyi, you'll need to run a wire from the c101 to the starter to get your windows and blower to work.
        I'll try to find some pictures. If you have all the wires though it should work perfectly fine. I don't remember doing anything special, but I'll look at my notes and see if I wrote anything down.
        Originally posted by LJ851
        Feedback
        • e30_kid89
          • Apr 2006
          • 489
          I've used my m20 harness to work on my m30b34 with b35 electronics and on the stock m20 computer. It started up first try and idled fine, never drove it though like that, I did away with motronic to run MS before fully completing the car - again re-using the m20 harness :D
          • Erick
            Official R3V Drifter
            • 11169
            I'm using an '89 325i harness. I actually went the extra step into wiring the injector twist clip for easy removal (given I'm just driving this M30 'til I blow it).
            I dont remember doing anything crazy, but have you made sure that you connected everything in the right place? The crank position sensor plug and the oil pressure plug are identical and go side by side. Easy to confuse those.
            Check all connections that could've been mistaken and go from there.
            ..::Support FullOpp::..
            FullOpp Stickers for sale!
            Feedback Thread
            • LowR3V'in
              • 4209
              I'm also using the m20 harness with no problems.
              • Paz
                • Jan 2010
                • 10
                I wonder if i have enough main power leads in the M20 harness, hence having to connect another live to get the starter to crank. I have two power leads coming from the body harness, and i think only one that comes from M20 harness. I have some other leads that are earthed/grounded to the strut top, i wonder if this is wrong... But im sure i copied it from another 325 correctly.
                Also, on the crank and spark signal plugs, identical as you said, is there any way of identifying which plug on the harness is for which sensor?
                Thanks
                • yert315
                  • 2734
                  There should be three terminals on the starter with 4 wires connected to them (two of which go to the middle terminal).
                  As far as the spark and cp wire, just switch them and see if you get spark.
                  • Paz
                    • Jan 2010
                    • 10
                    Im just wondering, are the c101 loom and body side the same? I just read someone said the pins didnt line up and would need swapping around.. Need to check for some pinouts on the c101's..
                    • yert315
                      • 2734
                      They should match up fine, assuming you have the correct plug. If it plugs into your body side harness fine, your wires will match up like they should. No swapping of pins necessary
                      • Paz
                        • Jan 2010
                        • 10
                        Yeah i checked all the c101 stuff out today, the only thing different is the 318is harness has an ABS something in pin20, the M20 harness has a ground for the coolent sensor apparently. I got rid of the ground upon recomendation from a friend..
                        Did some digging at key points and found i have voltage at the main relay, voltage at the coil and voltage at the starter switch pin in the C101 connector. I dont have any voltage at the fuel pump pin, and i dont think i have any spark.
                        Will carry on digging.
                          • 34844
                          if you don't get a crank signal to the ECU, you won't have spark and the fuel pump won't turn on. did you get it cranking over at least?
                          • Paz
                            • Jan 2010
                            • 10
                            Yeah, i can get it cranking by adding a bit of the M30 loom, its like another feed from the battery +ve to the main pin on the starter solenoid. Then it cranks off the key..
                            I'll need to charge the battery and swap the crank and spark signal wires over (as im not sure which is which), but im sure i did that yesterday to no avail.
                              • 34844
                              On M20s the passenger side is for the crank sensor, drivers side for the spark sensor.
