89 m20 into 91 318is?
    Hello,
    Just wondering because I found one thread that stated that putting a "90-92" m20 into a 318is uses the same plug/wiring.
    My question is what is the difference? Wouldn't an 88-92 m20 in theory use the same late model wiring? Obviously using m20 motor mounts but confused on this wiring issue. Any input?
    pretty much should slide right in. c101 is the same right dan? get a pinout off a forum and just check them
      That's what I was thinking Jeff. Didn't want to plug it all in and have it go "pop"
      i'll look.
        Anyone?
          I used an M20 engine harness to run my M30, and yes it plugged straight in, and worked but with one concession that i havent figured out yet. Pin 20 on the C101 318iS side has an ABS wire, whereas pin 20 on the M20 C101 engine side has a ground/redundant wire.
          I didnt really want to send my ABS to ground as im told there should be no gounds in the C101, so i cut it just to get my car running without that shorting out or whatever. I do not know if it makes any difference, i guess i could hook it back up and see if it still runs. My ABS no longer works. lol.
            Thank you for your input Paz, much appreciated.
