E30 M30 Swap Writeup - Complete
This is a sticky topic.
  • stanhayward
    • Mar 2013
    • 765
    #136
    Hey Frank, sorry for being a noob I thought it was a hard copy and included a shipping address with my order a few minutes ago. Just ignore that.... And thank you sir!
    1990 325i Touring - The Bonsai Bimmer - Patiently Waiting
    1984 316 Coupe - The Base Model - Pain in the Ass
    1988 750iL - The Daily Driver
    ...And a couple others...
    • VBe30
      • Oct 2013
      • 173
      #137
      Your website is down. No more swap guides....? I was looking to pick one up now for the future, just in case something like this happened!
      89' 325is - Alpine
      • Garageaholic
        Freestyle Fabricator
        • Dec 2005
        • 5204
        #138
        Interesting
        Recent Rebranding!!
        E30 SM62/S62
        E30 M60 V8
        E30 M30 Big 6!
        Instagram.com/garageaholic
        Youtube.com/garageaholic
        • Garageaholic
          • Dec 2005
          • 5204
          #139
          Please standby and I will get this sorted out. Sorry for the inconvenience
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          • Garageaholic
            • Dec 2005
            • 5204
            #140
            It's up now, and rear window Flyouts are coming soon!!
            Recent Rebranding!!
            E30 SM62/S62
            E30 M60 V8
            E30 M30 Big 6!
            • scoobydo
              • Sep 2013
              • 137
              #141
              Frank,
              I have a 333i that cam with the M30 b32 engine, looking to change out the radiator to an E28 type rather than the Alpina radiator. I have mounts from Tino to replace my Alpina ones thus pushing the engine back further but this then means a change of sump and oil pick up/oil pump. I would prefer just the pick up so that I can retain my current pump as that is good condition and low mileage do you know if that is possible. If not may look to chop and weld my Alpina sump.
              Sorry slightly off topic but relevant tks in advance
              • Garageaholic
                • Dec 2005
                • 5204
                #142
                Hey scoobydo,
                So if I understand you correctly, and regardless of your radiator discussion, you basically want to move the engine further back. Using the 2nd generation m30, you must replace both the pan and pump/pickup.
                1. You will have an interference on the oil pan itself when pushing the engine further rearward.
                2. Because you must replace the pan, you must get the appropriate pump/pickup from the newer m30 as they are compatible with each other.
                Nowadays it's cheap to get a new style m30 pan and pump/pickup.
                Good luck!
                Frank
                Recent Rebranding!!
                E30 SM62/S62
                E30 M60 V8
                E30 M30 Big 6!
                • scoobydo
                  • Sep 2013
                  • 137
                  #143
                  Yes the 333i had mounts that only facilitated the use of the Alpina radiator, this radiator sits partly in the front aperture taking up valuable room for front mounted intercooler. My radiator has decided to give up the ghost so taking the opertunity to change my intercooler arrangement. The Alpina sump is a pain as its bowl is rather rearward with not much space between the steering rack. I want to update to position 3 but have measured up and will have interference on the sump. Can get the sump and oil pump and pick up 2nd hand quite cheaply but nervous of putting an unknown pump on my engine which has done less than 80k miles hence wondering if I could just use the later pick up.
                  What source do you know for cheap pump/pickups?
                  Thanks for advice
                  • Garageaholic
                    • Dec 2005
                    • 5204
                    #144
                    Try car-part.com: a junkyard website. Search for any e34 or e32 535 or 735. Or the forums. eBay, sorry to say, is a ripoff.
                    When you get the parts, inspect them closely and see what parts from your alpina that you can mix and match. I'm sure there's some commonality, but I'm not sure which parts specifically. I'm thinking some pump internals might be reused.
                    The pan gasket, go to www.thebmwpartstore.com. In my experience, the CHEAPEST place for parts for your bimmer.
                    Recent Rebranding!!
                    E30 SM62/S62
                    E30 M60 V8
                    E30 M30 Big 6!
                    • dburgoon
                      • Sep 2012
                      • 558
                      #145
                      PM'd you!
                      Check started threads for stuff for sale!
                      Current:
                      '86 325es---5.0 Work in progress
                      2002 is300
                      • scoobydo
                        • Sep 2013
                        • 137
                        #146
                        cant see it which is odd or was that directed at Frank?
                        • VBe30
                          • Oct 2013
                          • 173
                          #147
                          Awesome! Thanks! - Just picked up the M30 Guide..
                          89' 325is - Alpine
                          • Garageaholic
                            • Dec 2005
                            • 5204
                            #148
                            Thanks for your patronage!!!!
                            Recent Rebranding!!
                            E30 SM62/S62
                            E30 M60 V8
                            E30 M30 Big 6!
                            • Garageaholic
                              • Dec 2005
                              • 5204
                              #149
                              All,
                              This is still for sale to help all of my E30 Enthusiasts!!
                              Recent Rebranding!!
                              E30 SM62/S62
                              E30 M60 V8
                              E30 M30 Big 6!
                              • Bullhead
                                • Sep 2014
                                • 532
                                #150
                                Is this still available?
                                sigpic87 325E The Honey Badger
