Why is it necessary to run something besides 3.73 and 4.10 again? I know you shouldn't use those gears but I forget why
Dif gear ratio's
It's not necessary, it's just with 3.7x, 3.9x, 4.1x the first gear is pretty much useless and you'll be in 3500-4000rpm in 5th doing 70mph....
See example here - http://www.r3vlimited.com/board/showthread.php?t=166604Last edited by Jean; 04-02-2010, 06:23 PM.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
For the M30, it has less to do with the gear ratios in the transmissions (E36 transmissions are direct-drive 5th gear whereas E30 and E28 transmissions have an overdrive 5th gear) and more to do with the rev range and torque band of the motor. You could run a 3.73 or a 4.10, but you'd probably be quicker with a numerically lower diff since the lower gears wouldn't be useless, and you'd be revving less on the highway; it's dumb to have a big M30 under the hood and still be at 3500rpm at 80mph.paint sucksComment
I´ll be hooking up a 3.73 to a Getrag 260/6, hopefully 1st and 2nd will be somewhat useable.
BTW, Jean, I laughed my pants off with Die Antwoord. So...tacky, so...german ghetto? so...budget minded, and at the same time, nothing short of BET productions quality. Don´t nobody get offended by my comment (entertainment purpose only). Think outside the box.1998 528i auto on staggered DSIIComment
