m62 swap links?
  • weaksauce
    • Apr 2009
    • 550
    m62 swap links?
    any of you guys have any links to some M62 swap threads?
    I picked up a 97 m62 that I was considering making a little project out of.
    i have the fab skills and the tools (I think)
    I am good with electrical work, I built the cage for our lemons car, and have rebuilt the motor in it, so I was thinking about grabbing a cheap roller and stuffing this M62 into it.
    so, links?
    Thanks in advance!
  • Jean
    • 18228
    Make sure to refresh the motor, they are notorious for various leaks (valley cover being the big one).
    • Jonsku
      • Oct 2004
      • 566
      www.e30.de & google translate
      - E34 M5 (x 2) -
      - E30 V8 Cabrio "Kylpyamme" -
      - Alpina D10 Touring #33/94 -
      - E46 318i Touring -
      - Toyota Hiace 4wd -
      • weaksauce
        • Apr 2009
        • 550
        i was going to do a complete motor gasket kit, along with rod and main bearings, and possibly new rings and head gaskets, just to make sure i don't have to pull it out again.
        i need to finish stuffing the m30 in my green car, then sell it and start then next project...
        • Dominic49
          • Feb 2007
          • 1373
          obd1 the motor or contact TRM about getting it OBD1 converted
          • weaksauce
            • Apr 2009
            • 550
            local wrecking yard has a 94 530i i can grab the harness from. i'll grab it next time i'm out there.
            what manual trannys will fit the m62?
            • Jonsku
              • Oct 2004
              • 566
              All M60, M62 and S62 transmissions and flywheels are bolt-on. 5-speed and 6-speed boxes have different sized clutch-shafts.
              - E34 M5 (x 2) -
              • weaksauce
                • Apr 2009
                • 550
                thank you sir.
                i'll start digging.
                what dif are you running? what tranny
                whats the cruising rpm at highway speed?
                • Dominic49
                  • Feb 2007
                  • 1373
                  you also need all the sensors and the front timing cover and trigger wheel as the m62 doesnt have the provission to hold the cps
                  • weaksauce
                    • Apr 2009
                    • 550
                    good to know.
                    should i just buy the whole motor, take what i need and shit can the rest?
                    i also have a line on a 94 530 i can grab for a couple hundred dollars, but it's an auto....
                    maybe i should just dump the m62 into it and drive it....
                    • Jonsku
                      • Oct 2004
                      • 566
                      I've 3.15 diff with 6-speed E39 M5 box, top speed ~299km/h so it'll rev around 2200rpm @ 100km/h..
                      good to know.
                      Easiest would be to get manual 530 where you'd take all the little parts you'll need along with flywheel, gearbox etc..
                      Standard B30 clutch won't hold B40 torque btw, so you'll need to find suitable clutch for that.. B40 clutch won't fit because it has different sized shaft and is 265mm in diameter (B30 clutch is 240mm)..
                      - E34 M5 (x 2) -
                      • weaksauce
                        • Apr 2009
                        • 550
                        so i'll need some type of performance clutch for the b30....
                        got it.
                        • BimmerScreamer
                          • Dec 2008
                          • 413
                          doesn't the e34 have the m60, e39 has the m62. Not that it makes much a difference in terms of the physical swap.
                          Anything can be done
                          • Holland
                            • Nov 2008
                            • 7212
                            OBD1 swap.
                            Originally posted by DEV0 E30
                            • foofopps
                              • Sep 2009
                              • 529
                              AKG guys have swapped 4.0 and 4.4 so they might be of help for info
                              Originally posted by b3albakii
                              the head was okey .. and in a good mood
                              no i didnt over heat it so much
                              www.blunttech.com
