m62 swap links?
  • HellzMindPlaya
    • 395
    based on what uuc's website says, the e39 m62 6 speed uses a clutch with a 240mm diameter... so could i just use that clutch with a 5 speed out of a e34 530i? I have a line on a 5 speed transmission for $350, but if I can't get it to work correctly because I can't find a clutch that will work I will just start saving for the 6 speed.
    I don't think anyone really makes performance clutches for 530i 5 speed cars do they?
    So if I can just use the clutch out of a e39 540i then should I use the flywheel that would come out of the 34 530i? Can you even turn a dual mass flywheel for reuse, or would I even need to?
    e30 Sold long ago - Too many BMWs since then... For now 2006 M5
    • BimmerScreamer
      • Dec 2008
      • 413
      so far for my v8 swap I have a m62b44 and a 5 speed off a e34 530, I am not sure what i will do for flywheel and clutch
      Anything can be done
      • E30SPDFRK
        • 5699
        Damn, another V8er in NE lol.
        I've got kind of the opposite though haha, an m60 with a 6 speed. I've got an e39 M5 clutch and flywheel, so I'm not sure what I'm doing in that regard either.
        I know that the e39 540i clutch will work on an 530i flywheel though, if that helps you at all.
        Byron
        Leichtbau
        • HellzMindPlaya
          • 395
          Looking at the sites that sell lightweight flywheels I more or less figured out the the clutch for the e39 540i and a clutch from the e34 530i are the same diameter. That still leaves me with the question as to if the input shaft on both transmissions is the same size. If it is then I am golden, and i will just go with a lightweight flywheel and clutch setup from a e39 540i. Any idea about the input shaft diameter?
          • Jonsku
            • Oct 2004
            • 566
            5-speed 'box has smaller clutch shaft than 6-speed, so 540 clutch disc won't be suitable with 530 'box.
            -E34 530, E39 530, E39 540, E39 M5 have 240mm clutch.
            -E34 540 has 265mm clutch.
            I doubt the performance difference in clutches comes from the clutch-disc itself, but from the pressure plate which bolts on also to 530 double-mass flywheel. So use 530 clutch disc and e39 540 pressure plate and you should be fine..
            All the V8 flywheels bolt to all V8 engines (M60, M62, S62), but the clutch shafts are different diameter in 5- and 6-speed boxes. The clutch slave cylinder seems to be the same in E34 530 and 540, so there won't be problems with clutch movement.
            - E34 M5 (x 2) -
            - E30 V8 Cabrio "Kylpyamme" -
            - Alpina D10 Touring #33/94 -
            - E46 318i Touring -
            - Toyota Hiace 4wd -
            • HellzMindPlaya
              • 395
              Thanks for the response. I have just deduced that from some searching on the web again. e39 540i 6 speed has a 1 3/8 inch 10 tooth input shaft whereas the e34 530i 5 speed is only 1 1/8 inch 10 tooth...
              So I guess I will just go e39 540i lightweight flywheel and pressure plate, and use the e34 530i clutch disk.
              • HellzMindPlaya
                • 395
                So i have done a little more digging and have come up with a few things...
                1. Looks like a set of e53 (X5) 4.4L exhaust manifolds can be used without modification...
                2. If you plan to use the 5 speed from behind a e34 530i it shares clutches with the e36 m3 as they are the same transmission, just a different bell-housing. The clutch diameter is even correct. There should be a good deal of performance clutches available for these cars too!!!
                3. A light-weight flywheel for a e39 540i should work as the clutch surface is the correct size.
                4. With the 5 speed I should be able to use a e30 M3 drive shaft... From the sounds of it, I should be able to run a e36 328is drive shaft too.
                Now to start saving and buying parts!
                • noid
                  • 1535
                  As a supplementary to the translation, below you will find various topics covered by RTSAUTO: https://www.rtsauto.com/m60-swap-eliminating-ews-for-404-ecudme/ - Eliminating EWS https://www.rtsauto.com/e30-boosterless-brake-bracket-booster-delete-manual-brakes-for-swap-cars/ - Boosterless Brakes (manual brakes) https://www.rtsauto.com/manualbrake/ - Manual brake calculations https://www.rtsauto.com/wiring-harness-adapter-guide-for-e30-m60-and-obd-1-m62-swap-pinout-and-a-cheap-way-of-getting-x20-and-c101-connectors/ - Wiring harness adapter https://www.rtsauto.com/e30-m60-m62-v8-engine-mounts/ - Engine mounts https://www.rtsauto.com/radiator-and-cooling-for-m60-m62-v8-e30-swap/ - Radiator and Cooling https://www.rtsauto.com/mounting-an-m60-m62-without-subframe-spacers-and-without-drivetrain-angle/ - Mounting an M60 / M62 V8 Into an e30
                  Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
                  Your resource to tools and tips: www.rtstools.com
                  • dirtysix
                    • 806
                    • Jonsku
                      • Oct 2004
                      • 566
                      1. Yes, but they cost something around 750€ (~1000$). I think some E39 right hand side manifolds fitted too, not sure though..
                      2. Oh really, that's good to hear! Then there shouldn't be problems with clutch.
                      3. -
                      4. Yes that's true, though you might need to shorten it depending on your engine position. E36 328 driveshaft fits too, as do early 325e and all 324td shafts. It still doesn't make it stronger, so you might end up in a broken driveshaft situation like this (5-speed & M60 & 325 driveshaft):
                      - E34 M5 (x 2) -
                      • HellzMindPlaya
                        • 395
                        Very nice! So it will have enough torque to twist driveshafts... Sounds like way too much fun! Thanks again for the follow up!
                        • moatilliatta
                          • 6144
                          Any body tried b30 heads on the 4.4?
                          @Zakspeed_US
                          • Jean
                            • 18228
                            what would be the benefit of that?
                            • moatilliatta
                              • 6144
                              Ive seen some post saying they are the same casting, but also herd where they up the compression...
                              @Zakspeed_US
                              • Koen
                                • Aug 2011
                                • 54
                                Some S62 swaps, not sure if they'll be much use except to provide some eye candy ;)
                                E30 318is Touring | E34 525i Touring
