radiator m30 swap
  • brandonj1
    • 318
    radiator m30 swap
    can i use my exiting m20 e30 radiator, its a behr? and why would i have to swap the radiator for the m30 because its to thick?
  • drift
    • 566
    Time and energy to fit M20 radiator is way far too much, compare to M30 radiator which probably cost ~ $200 new.
    http://www.kingofeurope.net/2010/
    • lashtx
      • 133
      M30 E28 radiator correct. E34 won't fit if I recall correctly.
      • RickSloan
        • 2401
        the m20 hose are totally differnt, smaller, upper and lower on opposite sides... there is alot of issues. Plus the m30 should use an m30 rad, cooling is one of the most important issues with this car that you can not cheap out on. you have no clutch fan.
        have you started this swap? or are you gaining info? this is covered in many many threads. And if you don't know that its very different then you have alot of research to do, starting with opening your hood.
        Need Illustration or Design work? www.robbiebyerly.com
        • Jean
          • 18228
          We should just start banning people for asking these very very very basic questions.....
          • george graves
            • 20003
            Not true! You CAN notch your subframe. Apparently.
            Wow - Jean is grumpy today! (just messing with you)
            Originally posted by Matt-B
            • RickSloan
              • 2401
              yea this stuff is getting kinda out of hand...
              i mean i know i asked some basic ones but that was 2 years ago and thiings weren't as well documented... now everything has been covered and discussed repeatedly
              • Jean
                • 18228
                I am not at all, just maybe then people will actually read some of the available threads and learn a thing or two. IONO
                Ok, dinner is almost ready
                • RickSloan
                  • 2401
                  once he eats he will be happy again!
                  but yea it makes me feel we have wasted alot of key clicks explain all this over and over for it to not be read
                  • brandonj1
                    • 318
                    i am just doing research. and i have read through several build threads and they all say e28 or e34 with modifications, never says why, i was just curious why. i just got this radiator a month ago so i was reluctant to buy another and just wanted to be absolutely sure. thanks tho.
