Tranny Question
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Clutchmasters is right out the way from you, you could have them build an up-speced clutch disc for your application, and they should have everything else there that you need too.
    • wildstoats
      • Sep 2007
      • 896
      didn't otis runa stock 240 with a stock clutch on his 318?
      and just to clear the confusion. every m30, s38, s14 and m10 all share the same bell housing and can interchange transmissions given that the pressure plate, flywheel combo is correct for the trans.
      Good to know. Thanks!
      • Jean
        • 18228
        Yep. Early G240 is not the same as the late G240. Early one fits the m30 and the late one m50s....
          • 37829
          Dear god please do not run a stock M10 clutch on an M30.
          Trust me.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • GoKahth8ter
            • Mar 2008
            • 54
            notch?
            You'll need to notch the sub frame to run that trans.......
            • TwoJ's
              • Oct 2005
              • 4908
              I would recommend contacting Alpina and doing whatever they did back in the day. They should be able to provide you with part numbers and instructions for notching the bell housing to make it all work.
