is it possible to mate up this trans too this motor instead of using the bigger guibo driveshaft ..??
M30 with Getrag 260 ?
Tags: None
Try again. G260 is too broad of a question, there is an M20 G260 and M30. You can't use an M20 G260 as it simply won't bolt up.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827 -
yeah i was thinking m20 g260 is there any trans that is strong that will work on a m30 that has a small guibo output shaft "?? thats standardComment
use the m10 tranny until it blows up if you can't find an m30 tranny...OR get the m30 g260 and swap the output flange. you can make an m20 tranny work too, but you'll need to design / make an adapter plate...Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
i have an m30 trans and a m20 trans but i was just woundering if i could get a trans that wouldnt need too use the bigger guibo driveshaft . for the m30 that im putting in my e30 .Comment
you can swap the output shaft on the tranny...but i would research or measure the small guibo vs large guibo driveshaft lengths...Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
mhm .. i have 2 small guibo driveshafts .. so im sure i can measure fairly soon here .. is swapping output shafts fairly straight forward ?Comment
You sure you can just bolt on the m20 flange?
I posted this in another thread.
To me, it doesn't look like you can just switch the m20 one over.
By looking at the part numbers, there seems to be two different sized output shafts
in the m30 trans. Make sure you have the right size/year.
The larger m20 output flange uses the the same part number
the m30 trans in the e34 uses. So I'm guessing one could use the smaller flange going
by that if you have to e34 trans. But it's different for the e28 535i trans somehow.
What is the trans out of?Last edited by LowR3V'in; 06-17-2010, 10:50 PM.
