Forgot to add the Holset H1E turbo as well. Needing 350 for it.
I am desperate for money. Buy my M30 stuff.
Whats the shape of your AFM? Can you run a resistance check on the sensor as you move the paddle through the full range? Me E30M30 is getting a little low in the middle section so the engine "sees" less air going in that is actually making its way through to the engine.Comment
Nope, sorry. AFM is gone. I'd ditch the AFM if I were you anyways if ya can.Last edited by Operator62; 07-10-2010, 12:09 PM.Comment
LC-1 wideband. NO GAUGE. NOT NEW, but it is in the box. lol Installed, calibrated, but car never ran with it installed.
If the M5 clutch will "fit" an M30 then I don't see why the M5 clutch wouldn't fit a flywheel made for the M30. Do you mean like an e28 M5 clutch or an e34 M5 clutch?
The e28 535i and M5s will use the same JB Racing flywheel, but the e34 535i and M5 use different ones. Now, I don't know that any of the bolt patterns or anything like that is different, but the e34 M5s flywheel weighs 8lbs whereas this one is 11lbs. So, it really depends upon what year engine you are running I do believe.
Pretty sure I don't have 7. 3 is possible..., but I know I have 19 for sure. I can send you the whole IAC if you want it.Comment
