I'm going out to the junkyard today to pull a driveshaft for my e30 m30. Does it have to be off a 535i manual or can it be 535i/528e with manual/automatic? noobie would appreciate advice here. Thanks!
Which front half driveshaft?
Sorry for the delayed response. I have the g260/5 and am in position two as well. Got my front portion of the driveshaft a couple weeks ago and had it fitted together to the rear portion e30 by a friend. Made a bracket extension for the center support bearing and everything fit up just fine! BTW, i have the e30.de mounts.
this issue appears to be solved by the old "trial and error" technique...since most people have different configurations...I´m not even bothering until the engine and tranny are mounted on the car, so I can measure stuff. Hope you find what you need trouble-free.1998 528i auto on staggered DSII
Gadea...what year is your e30? For the most part (from what I hear) you just need the same setup I've gone with and you should be worry free. But I guess it all depends on which mounts your using and the position you go with. Mine fits perfectly though and only cost me $65 for the front portion.
