^ Sometimes I have more value than random comments. Sometimes.
The OFFICIAL let's make Erick's M30 stop overheating thread
I've been watching this thread and it sucks there still is no "fix." I have a similar issue where i will run hot (up to 3/4 and it would keep going) on hot days when im in traffic. Once i'm cruising its below 1/2. I squeezed in a 14" spal pusher and a 7" fal pusher fan on the engine bay side and the 7" fan just slows down the overheating but doesn't stop it. I'm running the coldest thermostat as well. It's frustrating and i'm hesitant to take it out for HPDEs because i don't want it to overheat on the track or something.
I'm going to look into getting an custom rad made with more cooling capacity but with the room upfront i'm not sure how well thats going to work.
Has anyone ever ran 2 rads? lolComment
are you sure you have the correct water pump pulley?
thats the only thing i could think of that could be screwyLast edited by bataangpinoy; 09-08-2010, 07:41 AM.My feedback:
http://www.r3vlimited.com/board/showthread.php?t=186328
http://e30tech.com/forum/showthread.php?t=74911
Instagram:
@gears_n_glory
@functionmotorsportsComment
On his setup the expansion tank is hooked up from the thermostat housing which would explain why coolant is being pushed into the tank and pressurizing it. Coolant flows from the back of the head back into the thermostat housing.
I think he should try using an upper radiator hose that has a T to go to the expansion tank and just route the back of the head to the thermostat housing.Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
____________________________
E-mail Panayiotisx2@gmail.com
Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=ULComment
The only thing I would question then is the coolant line configuration. On my B34 the upper radiator hose T's off to the expansion tank.
I think he should try using an upper radiator hose that has a T to go to the expansion tank and just route the back of the head to the thermostat housing.Erick Mahle | FullOpp Drift | YouTube
..::Support FullOpp::..
FullOpp Stickers for sale!
Feedback Thread
Originally posted by Mr. Anderson...one of the most hardcore E30's around. :DComment
Feedback Thread
what he's saying is to delete the t fitting, and then find an e34 upper rad hose with a t fitting as the coolant over flowMy feedback:
Instagram:
@gears_n_glory
I see. I will see if I can source one of those hoses to give it a shot.Erick Mahle | FullOpp Drift | YouTube
Feedback Thread
Yea, I will make a run to the Finish Line today to see if I can get the hose. Also hoping that it solves my problems :)Erick Mahle | FullOpp Drift | YouTube
Feedback Thread
Not yet. I'll look into the hose tonight and then make the shroud if that fails to make a differenceErick Mahle | FullOpp Drift | YouTube
Feedback Thread
