One last wire for my m30 pic inside
  • justin_l_
    • Jun 2007
    • 1079
    This blue wire, I have no idea where it is supposed to go. I want to say it goes to the alternator but I'm not sure and don't want to burn stuff up. It comes out of the main harness where the loom for the relays come out.
  • wildstoats
    • Sep 2007
    • 896
    That is more than likely the charging indicator. But I would trace it back to make sure.
    • StereoInstaller1
      GAS
      • 22679
      Justin, are you aware of the wiring diagrams that are online? Tough to use, but they are the factory shit.
      You can find them at www.wedophones.com
      Closing SOON!
      Thanks for 10 years of fun!
      • justin_l_
        • Jun 2007
        • 1079
        Yes I know the diagrams are there but I honestly don't know what year or car the harness is from. I'd usually check them first but I thought I would check here first. Tried to trace it back to the ecu conector and didn't find it...
        • StereoInstaller1
          GAS
          • 22679
          yeah...not knowing what car would be a bitch. I would check any M30 car (e28, whatever) and see if it jives with anything
          Closing SOON!
          • justin_l_
            • Jun 2007
            • 1079
            Bump, not really having any luck
            • justin_l_
              • Jun 2007
              • 1079
              This is the setup I am using if it helps identify...
              • george graves
                • 19996
                If it's the charging wire thing your car will run and start, but your alternator won't charge.
                IIRC the other end goes to the charging lamp in the cluster.
                Originally posted by Matt-B
                • justin_l_
                  • Jun 2007
                  • 1079
                  If it is the charging indicator I should be able to trace it through the c101 correct. Which post on the alternator would it be connected to?
                  • justin_l_
                    • Jun 2007
                    • 1079
                    The wire was the charging indicator light
                    • quickervicar
                      • 1197
                      Thanks for the followup. So often these just go unanswered
                      • justin_l_
                        • Jun 2007
                        • 1079
                        I know. Makes searching useless when people don't follow up with answers. Thanks for the help guys. This touring is on it merry way back to the customer.
