For the m60b40 gurus
  • bimma360
    • 1940
    Just wondering... would the late model e30 radiator work with the M60 swap? I know the e34 540 and e28 535 radiators are viable options, but I was just wondering if there would be any issues using the late model e30 unit.
    Dave
    E30 Dinan Turbo
    • Jonsku
      • Oct 2004
      • 566
      Originally posted by Jean
      "Check the guide rails for chain, if they look good they're not worth changing (are a bit pricey, you can get whole engine for the price of them). "
      WUT?
      Dunno what's the price level there but here you can get whole M60 engine (without ancillaries) for 400-500€ (500-600$). Though now when i looked at the guide rail pricing (around 200€ for all rails), i must say i remembered bit wrongly, though i guess that if you change the guide rails you should change the chains and tensioners, which add 300-400€ ending up in the complete engine price..
      Ok, did the 92-95 and 96+99 have the same crank/rod/pistons/block or were there differences? I am not talking about the m60 vs m62, but just the m60 stuff.
      M60 was made only until early '96, the block itself is the same in 3 and 4 litre versions but most of the internal stuff is different including bore. Don't know if the heads are similar, though.M62 has also "same block". Here're the basic facts of M60..
      - E34 M5 (x 2) -
      - E30 V8 Cabrio "Kylpyamme" -
      - Alpina D10 Touring #33/94 -
      - E46 318i Touring -
      - Toyota Hiace 4wd -
      • Jonsku
        • Oct 2004
        • 566
        Dave
        Yes there'd be, because the rad is too small. "Tropical version 325e / 324td" radiator could do the job but normal E30 rads are way too small. E28 535 rad is the minimum you need in there, and that's a straight "bolt on" so there's no reason not putting at least that one in..
        - E34 M5 (x 2) -
        • bimma360
          • 1940
          Got ya. Makes sense, thanks for the info.
          Dave
          E30 Dinan Turbo
          • E30SPDFRK
            • 5716
            see if it will be cheaper/easier to just switch to the tilton setup instead of relocating the booster/mc etc...
            Yes.
            The brakes were the biggest pain in my swap. It seems simple but it takes a long time to get it all working correctly. If I were to do it again I'd just go with a manual setup.
            Byron
            Leichtbau
            • bimma360
              • 1940
              So, lets talk about AC... is there even any room for it?
              E30 Dinan Turbo
              • Jonsku
                • Oct 2004
                • 566
                double-post..
                - E34 M5 (x 2) -
                • Jonsku
                  • Oct 2004
                  • 566
                  Yes there is, but then you need to use original engine mounting arms and weld some mounting points for them on the body rails. Original E30 mounting points on front subframe are located too much back.
                  A bit of hammering of the body rail is also needed, as is the case with the alternator on the other side.
                  - E34 M5 (x 2) -
                  • 2002maniac
                    • 4260
                    Jeean, the E39 6-speed is exactly the same as the box in the E34. I'd go for the M62. Might as well go for the 10% displacement increase.
                    I'm loving my E34 540i/6, but part of me wants it to get totalled so I can swap all that goodness into an E30 :p
