M30 Build
  • Jean
    • 18228
    Yes, OP. did you read though the M30 faq/build thread?
    • Frog
      • Jun 2010
      • 980
      Do you have a manual tranny for that?
      Winner winner chicken dinner?
      My Seller Feedback Thread
      • zlatan55
        • 36
        yes i do, still have to change the main seal and shifter bushings, bought a m5 clutch and resurfaced flywheel.
        thanks everyone for answering my oil pan question i guess now that i have to run a different oil pan... do i have to buy different oil pump or can i just relocate it. Found a pan for $150.00 on ebay... maybe it would be better to visit local pick up part
        • rav320uk
          • Jun 2004
          • 1337
          What car is that M30 from??
          If you have bought items from me, please leave feedback below.
          If you are a BUYER, Check My Feedback.:up:
          http://www.r3vlimited.com/board/showthread.php?t=183860
          Check out my Euro Build Thread
          http://www.r3vlimited.com/board/showthread.php?t=215557
          • kronus
            • Apr 2008
            • 13028
            86 535i that I briefly owned. 150k miles!
            cars beep boop
            • Good & Tight
              • Apr 2004
              • 2057
              You need a E34 oil pump for that pan.
              Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
              ____________________________
              E-mail Panayiotisx2@gmail.com
              Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
              • rav320uk
                • Jun 2004
                • 1337
                E28 then, you'll need to block off the water hose on the rear of the head too as it won't let your engine sit far back enought to the bulkhead.
                • zlatan55
                  • 36
                  having trouble finding oil pan, anyone selling one, Kronus thanks for the motor do you know if your buddy got one in his garage?
                  • kronus
                    • Apr 2008
                    • 13028
                    I don't think he does. I've seen E32s and E34s pretty frequently in Ontario Pick-n-Pull, though.
                    cars beep boop
                    • kronus
                      • Apr 2008
                      • 13028
                      Is it safe to block it off? The solutions I've seen involve either cutting or beating the firewall to make room for the rear coolant pickup.
                      cars beep boop
                      • LowR3V'in
                        • 4209
                        The b35s have it blocked off.
                        • zlatan55
                          • 36
                          guys any suggestions how to properly torque down head studs (stock) do i have to run some sort of heat cycles and how many times? thank you
                          • LowR3V'in
                            • 4209
                            if you do a search here there is a Bentley manual in pdf.
                            Don't know it from memory but you torque them down by like 20ft at a time and
                            wait 15min in between steps.
                            • jim325
                              • 228
                              EDIT: Um, that is for e28 535i motors...b34 not b35.
                              Bolts have a specific order in their tightening sequence, and 3 stages.
                              Stage 1: tighten bolts to 22ftlb's
                              Stage 2: tighten 90 degrees
                              Stage 3: tighten 90 degrees
                              That is for Torx head bolts. Hex-head bolts are different.
                              Stage 1: 29ft lb's(plus or minus 4 ft lbs.)
                              stage 2: wait 15 minutes after previous torque 44 ft lbs(plus or minus 4 ft lbs)
                              stage 3: run engine until it reaches operating temperature. tighten 25 degrees (it is ok to go 5 degrees over but don't go under)
                              Kinda hard to explain the tightening pattern but start at the middle of the cylinder head and work your way out alternating top and bottom.
                              89 325i: 86 535i motor+trans, JE forged pistons, MLS head gasket, ARP head studs, Comp turbo, GoodNTight b34 turbo manifold, e30.de motor mounts, AKG 75D engine/trans mounts, custom 3" exhaust, intercooler, MS2PNP, Megan Racing Coilovers.
                              • zlatan55
                                • 36
                                hmm. thats what i did, minus the warm up because i have not ran the motor. my block has a stamp 3.5 but the motor came out of 86 e28 535i! i was wondering the same thing! Kronus any thoughts?
