if you want the power of your e46 in ur e30 then go with either the euro s50b32 or s54..
S52 or E39 V8 swap?
Not to be rude, but search, this website has tons of info and a lot guys will help when asking specific questions.
So far all I've read from you is that you have asked basic questions without seaching here or google and you can do vinyl wraps; not of which instills confidence in doing this swap.
Good luck.1985 BMW 325e
1997 BMW M3/4/5
2007 Chevy Silverado Crew Cab 5.3 v8
Originally posted by e30e View PostNot to be rude, but search, this website has tons of info and a lot guys will help when asking specific questions.
Good luck.
Not to be rude but I've searched for a week. I have found some helpful info, mainly now all I'm looking for is a parts list for an S50 swap. I'm still searching. I've also done all my work on every M3 I've owned, I'm just not familiar with E30's. Just hoping for some help man. Usually forum guys are a pretty good group and helpful (that's not a dig at you, I swear). I'm a very strong contributor on M3 forums even though I could tell guys to search but I help them out because this is my passion. Take that as it is, just a comment. Not meant to insult or offend anyone :)
Originally posted by stormspike View PostWent the us s52 route on mine and ended up going to the euro s50b32 this last summer. Damn fast now. I would suggest starting there. Save you time later when you get tired of the us motor.
Well.. if you'd used the time that you spent posting all kind of non-related stuff here you'd found out all the info you need for the S50 swap. S54 is also possible and not so expensive after all..
Before posting any more to this thread go through these forums;
r3vlimited
e30tech
e30zone
all you need to know (s5x, m6x) is listed on those forums..- E34 M5 (x 2) -
- E30 V8 Cabrio "Kylpyamme" -
- Alpina D10 Touring #33/94 -
- E46 318i Touring -
- Toyota Hiace 4wd -
Originally posted by Jonsku View PostWell.. if you'd used the time that you spent posting all kind of non-related stuff here you'd found out all the info you need for the S50 swap. S54 is also possible and not so expensive after all..
r3vlimited
e30tech
e30zone
For those that search and find this thread, here you go:
This thread is a great idea Ryan. It seems more and more people are becoming serious with the DOHC(M50/S50) engine swaps rather than just throwing a whim of a dream they had onto the forums. This is some very helpfull info that I saved a few months ago from Chuck Waits. Hope this can help.
E30 M50 ENGINE CONV PARTS LIST
"1. E30 88' radiator, I used the e36 unit with the lower mounts raised
2. E30 88' radiator over flow tank
3. E30 M20 fan, poss. w/clutch
4. E28 533i motor mounts w/ 5mm spacers or e28 m5 mounts with out spacers
5. E34 throttle cable
6. E21 brake booster w/ modified shaft, to 15mm or 325IX/e32 735 without mod to the shaft
7. E34 M5 or 25mm brake master cylinder w/ additional brake line used for the 325ix booster
or a e32 735i with the modified 320i booster
8. E30 325 trans X-member
9. E28 m5 or two 320i trans mounts/ which are cheaper
10. E30 M3 driveshaft or i used the front of the e36 mated to the rear of my e30 M3 have it rebalanced
11. E30 diff. w/ 3:25 ratio or E28 533i w/ 3:25 LSD
12. E30 318 ECU mount
13. E34 oil pan
14. E34 oil pickup
ect. ect.
15. E36 m3 exhaust manifold
16. M50 radiator hoses
17. E36 M3 Motronic
18. OBDI intake manifold
19. OBDI throttle body boot
20. E36 alloy mounting arms
21. OBDI wiring harness DO NOT BUY silver label “413” motronic, it has EWS (security),
it can only put into original chassis
22. the engine harness and the ECU are all E36 M3.
On the standard E30 with M20 engine fitted, you have the large round plug (C101) up on the firewall next to the brake booster.
This plug has 2 parts. One half is connected to the car wiring, and the other is connected to the engine harness.
When the M20 was removed, the engine side of the plug was removed with the engine. Now I have the S50 half of the plug in its place. Although similar in appearance, it will not plug directly into the E30 half of the plug.
I removed the E36 engine half of the plug, and replaced it with an E30 one. This then allows the 2 parts to screw back together. All you need to make sure is that you have the correct wires connected to each other. Its not just pin 1 to pin 1 and pin 2 to pin 2 etc (although some of the wires do actually connect this way).
This plug connection is the only point where the E30 & E36 wiring interface with each other. The rest of the E36 M3 engine harness is totally self contained.
23. the exhaust from the downpipe to the muffler is all custom made
This is not a complete list but damn close if you need any additional info feel free to email or call me at
INTERNATIONAL AUTO
770-745-0501
my name is Chuck Waits, and we are open from 8 to 5pm EST"
