M30B35 swap into a 87 ETA w/auto
  • Rau
    • 449
    So I Want to drop a B35 into my 325e sedan. Love the torque, and I have no intention of boosting it at all. Maybe just some long-tube headers, intake, catless exhaust, cam, and chip, if anything. Now the only thing is I want to do this with an automatic tranny, as this will be a cruiser. I already have one car with a manual tranny, and do not want another. Will this complicate the swap, or is it feasible? How much should I expect to pay for a B35?
    And yes, I did do a search, and could not find any swaps w/auto's.
    Originally posted by RUFFLZ
    #BANDISNIGGA
    Originally posted by Wh33lhop
    Why the fuck would you ever put a drink up there? If you ever have a drink to hold, just put it between your legs. You know, where your balls used to be before you had a girlfriend.
  • LJ851
    • 7919
    It can be done. Are you very concerned how far back the motor is ? how handy are you with a hand held sledge ?
    Lorin
    The M30 is God's engine.
    • Rau
      • 449
      Pretty handy with a sledge? Should I just do a "drop-in swap" like a M50?
      #BANDISNIGGA
      • Wishno87
        • 6025
        If your looking for a drop in swap M30 is not the way to go. Especially with an auto tranny.
        • LowR3V'in
          • 4209
          People have done auto m50 swaps?????
          The m30b35 is totally drop in except for needing motor brackets.
          It's more drop in than an m50. Everything lines up and fits.
          No need to smash in anything.
          or mess with the brake booster,
          or rewire the harness,
          or costume tranny mounts, shifter linkage ect...
          • CorvallisBMW
            Long Schlong Longhammer
            • 13039
            Exactly. Easier than m50 IMO.
            The only problem with an auto swap is that most M30 auto transmissions were electronically controlled so you'll have to find a way to transfer all the wiring, computers, AT brains, sensors, etc in to your e30.
            • Rau
              • 449
              shit...... I dont know what I want/can do now......
              #BANDISNIGGA
              • LowR3V'in
                • 4209
                buy an e34 :P
                • wannaBMthree
                  • Apr 2007
                  • 601
                  Don't be a waffleswaffleswaffleswaffleswaffles, 5spd m30 swap ftw. Get a low ratio diff and you'll be fine.
                  • Rau
                    • 449
                    buy an e34 :P
                    Tempting, already was scouring CL for a clean one.....
                    #BANDISNIGGA
                    • slammin.e28
                      שמע ישראל
                      • 12054
                      Only the 4hp22eh was electronically controlled. It had a switch for economy, sport, and manual shifting. The m30 4hp22 works the same as any other e30 4hp22. As long at you're starting with an auto car, you'll be fine with a 4hp22. Just don't get a 4hp22eh. Also, you'll need a different t-body, as the kickdown cable has to mount to it.
                      I'd go for a rebuilt 4hp22 (just sold one w/14k miles) as they (all of them) like to fry the A-pack. (A o-ring breaks down and allows the fluid to seep out of the a-pack, causing it to burn out) The rebuilt ones use upgraded components.....and cost about 2x as much as a 5sp. (Sold mine for $600...and that's cheap. Rebuild kit is ~$4-500 alone)
                      Easiest route: Just make it a 5sp. It's not that bad, it's simpler, etc, etc.
                      But....if you're up for a challenge, GL! (I'd get a car that already is an auto, thus containing all the wiring, etc.)
                      • G-Man the Visionary
                        • Apr 2013
                        • 543
                        so... anything ever come of this? anyone know if the guts for an eh can be placed inside of a non eh? I can get my hands on an eh for my auto swap since i ruined the pump on my non eh, and was thinking about just having it rebuilt with the internals of the eh, or just convert the whole car to eh... please help!
                        Streetable poly mounts, trans mounts are here!
                        http://www.r3vlimited.com/board/show...ght=streetable
                        '94 318i
                        '07 335i
                        '11 X5
                        '89 325ic m30b35
