M30 swap what trans?
  • zeekracing
    • 16
    Hey I'm new to the BMW scene. I'm still trying to figure out all the names of stuff. I have a 87 325e with a 2.7 and 5 speed. My motor is toast and I found a 3.5 in a 92 I think it was a 525. I've been doing a lot of reading about the swap. I was wondering if my trans would bolt up to the bigger motor? Thanks for the help in advance. I will keep doing some digging.
  • LowR3V'in
    • 4209
    M20 trans won't work. :(
    It'll need to be from m30, m10 or s14.
    • ///Maddog9000
      • Apr 2009
      • 157
      The e34 at the junkyard is a 535...
      you want a g260/6 or a g265 for best results.
      g260/5 will work also.
      I'll sell you a clean g260/5 with good clutch for $350.
      '08 328i Sedan -daily touring car
      '89 335i Coupe -parting out
      '01 330i Sedan -divorced
      '90 325i Coupe -smashed
      e30m50tu@gmail.com
      • wille28
        • 113
        m42 tranny can work??
        • LowR3V'in
          • 4209
          • Doughnut
            • Oct 2007
            • 869
            Oh bother...
            ///Monstrosity. (OO≡≡[][]≡≡OO)
            Aside from showing yourself to be offensive, lacking experience and ignorant in the ways of business, you're also illiterate and imprudent. Beyond that, your sense of liability is severely impaired.
            • e30_luv_
              • Jul 2008
              • 186
              Does the "6" in g260/6 denominate that it has six gears or five? How hard are is it to find these transmissions?
              • LowR3V'in
                • 4209
                The 260/6 has these fins on the bottom. The /5 is just waffles.
                http://bigcoupe.com/ims/pic.php?u=21GvpX2&i=403
                Both 5spd
                • ///Maddog9000
                  • Apr 2009
                  • 157
                  the g260/5 was used for a short time then replaced with the g260/6.
                  e30m50tu@gmail.com
                  • e30_luv_
                    • Jul 2008
                    • 186
                    Both 5spd
                    Gracias Senors.
                    • zeekracing
                      • 16
                      Is the bellhousing bolt pattern different on the m20 trans? I was just woundering why it won't work. Thanks for the help
                      • Alpina
                        • Oct 2004
                        • 838
                        G260 is the same box inside on m20 and M30
                        but the M30 box is coded 260/6 and the M20 is G260/5 and the bellhousing is the explanasion
                        the G265 is also an option .. but lower gearing .. the G265/5 is the oem Euro M3 gearbox ,, and is a dogleg gearbox
                        the G260/6 is a great gearbox ,, strong and reliable
                        Sveinbjörn Hrafnsson
                        E30 CABRIO V12 M70B50 ///
                        ALPINA B10 BITURBO 346 @ 507
                        E34 550 V12 JML
                        Finnish wisdom : If you want to Win,, hire a Finn
                        http://alpina.123.is/pictures/
                        • alpinacsi
                          • 33
                          Not true.
                          For the m30: the 260/5 was used from late 82 until late 84.
                          The 260/5 was removed from production and the 265/5 was brought back for use in the 85 model vehicles while the 260/5 was redesigned.
                          The 260/6 was the revised version ans as previously mentioned; can be identified by the cooling fins on the bottom of the case.
                          The early 260/5 used the smaller clutch cover due to the case profile but the last of them would accept the M5 style clutch that could also be used in the 265 and 260/6.
                          All of these trans mentioned were 5 spd overdrive trans and the 265/5 was the C/R dogleg sport unit.
                          • canucke30
                            • Jan 2011
                            • 103
                            so my stock transmission in my '84 318i (m10) will bolt right up to an m30?? Oh damn, that is exciting! I gots me a line on a perfectly good m30 engine! What is a good price for one of these?
                            • rav320uk
                              • Jun 2004
                              • 1337
                              You'll need an uprated clutch if you're using the that g'box
                              If you have bought items from me, please leave feedback below.
                              If you are a BUYER, Check My Feedback.:up:
                              http://www.r3vlimited.com/board/showthread.php?t=183860
                              Check out my Euro Build Thread
                              http://www.r3vlimited.com/board/showthread.php?t=215557
